Hooking up Car stereo equip. in house?
I have a Fi Q 12" D1 in a 2.5cuft net enclosure ported at 32-33Hz via 2 3" flared Precision Aeroports sitting around. Also have a leftover Kicker ZX1000.1 to power it.
Would like to hook this stuff up off my computer if possible , currently using a little 2.1 Boston Acoustics I got for free.
Instead of spending money for a pc system I would rather make this stuff work if possible. What else do I need?
2000 Trans Am ws6 - 6spd / M9 / cam / full bolt-ons / semi full suspension / tune
1998 Integra - daily beater, [2] AB XFL-1244's / 4ft³@35Hz, 61in² / Saz-3500dv1 @.85Ω
look into a 2 ohm plate amp
R.I.P!
(Nov-29-2009)
92 explorer
current build
Computer power supplies don't put out too much amperage on the 12v rails... An all of your voltage ratings would be @ around 11.5-12v. If you exceed your maximum amperage output... Most power supplies will blow up or either go into protect and shut the unit off. I just use one for testing.. I don't go to the extreme of using it on a daily basis an actually playing music off of it for extended amounts of time.
1993 Chevrolet SWB Pickup
Viper 791XV
Primer Stage
5/8 Static Drop
Kinetik HC1800
Big 3 Knu Flex 0
Team Tex Flex
I would look into the SoundDigital FT120 power supply, you can run a 1200rms amp directly off of it.
¿ǝɯɐƃ ǝɥʇ
Are you tripping? PCP&C has one with over 100A @ 12v...
http://www.pcpower.com/power-supply/turbo-cool-1200.html
10.x volts fo' life!
You must have missed my point somewhere in there... Is it safe? No! 100amps isn't much for a power supply that's 83% efficient @ 12.5 volts at most. Will your cars amplifiers pull more amps at lower voltages.. yes! what size wires are you working with <16 gauge! will the power supply be able to keep up with demand for music... NO! Is it likely to go up in smoke... YES!. It's not a very ethical long term investment in my opinion... You might as well be plugging your amplifier directly to a wall socket to see if it works that way.
Viper 791XV
Primer Stage
5/8 Static Drop
Kinetik HC1800
Big 3 Knu Flex 0
Team Tex Flex
You'd be better off getting a small AGM battery and a small charger for it that'll keep the battery floating comfortably @ around 13.8 - 14.4. It'll even cost less and actually be efficient.
Viper 791XV
Primer Stage
5/8 Static Drop
Kinetik HC1800
Big 3 Knu Flex 0
Team Tex Flex
  • Who's Online   2 Members, 0 Anonymous, 702 Guests (See full list)
