what do you guys think of this box.. for a type r 10 off a kicker zx700.5
clarion cz500 head unit
Kinetik hc600
2 level 3 15s in a 4th order
mb quart 1500.1 (for now untill i get a dc 1.2k)
all knu konceptz wiring
in a 2009 ford flex
-DISKOLORED AUDIO-
-Authorized Dealer for DC Soundlab in Alaska-
what tuning is it? and how much airspace too lazy to do the math
RE audio says its 1.966 at 32hz
and the program is google sketchup
Kinetik hc600
in a 2009 ford flex
-DISKOLORED AUDIO-
so about 2 cubes... but then displacement of the sub should be factored in.. and those 45 degree angles that you put in there as well... should work out great though
you should try a few different calculators and see if they result in the same numbers
Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
sweet what other ones can i try
Kinetik hc600
in a 2009 ford flex
-DISKOLORED AUDIO-
ExpoSport's calculator works pretty well and is more accurate than the RE calc... Is the 2ft3 before or after sub/port displacement?? How much port area?? What kind of power are you gonna be running??
Pioneer AVIC-N2
looks pretty good, how were you able to post that from sketchup? Ive been tryin to figure it out all day
"God's country is like Heaven, Cause you can drive like HELL!!"
Never Argue With An idiot. They'll Lower You To Their Level And Then Beat You With Experience!
actually i print screened, uploaded to photobucket. and there it is..
Kinetik hc600
in a 2009 ford flex
-DISKOLORED AUDIO-
its 1.997 cubes, but with the 45 degrees, and sub displacement it should be right around max specs from alpine. i think its 1.3 cubes.
Kinetik hc600
in a 2009 ford flex
-DISKOLORED AUDIO-
