The PA amp is horrible, plain and simple... The Hifonics Bxi2008d is a pretty decent amp that will do around 1600-1800 or so watts @ 1ohm and isn't too bad on electrical either. Just make sure that you set the gains correctly and don't run it too hard and you'll be just fine.
Like I asked in your other thread, do u have any current electrical upgrades done to your car?? With the Bxi2008D you could prolli get away with having a solid under hood batt, big 3 upgrade in 1/0ga or larger wire, and a big batt in back.
What kind of budget do u have for an amp + electrical upgrades needed to back it up?? Also are you gonna be the one building the enclosure and doing the install??
Pioneer AVIC-N2
