stock electrical when running voltage has went up and dont know why
ok when car is off its 12.6-12.7 but when at idle i went from 14.4V stock to 14.8V and now 15.4V!
wtf??? all ive done is removed the ac compressor and its jumped up the two times since thus the 15V range now and no big 3 yet.
what could be making this happen and do i need to worry?
car: 99 olds aurora
alt: stock 140A
plus big 3 is gonna be more time consuming than most cars since my stock location of my battery is under the seat with big fuses ill try to take pics or vids
1998 Monte Carlo Z34
Stock HU but have replacement
Stock Highs
Stock Electrical
BTL 18 sitting naked
AP1500D
wow thats weird. im curious too i wonder if anybody knos
2002 Dodge durango 4.7L
Autopage 2 way remote start alarm system
2 AQ 15 Aluminum coils.
1 AQ2200D (soon to be 2).
8.5 cubes tuned to 38hz.
Yellow top under hood.
Kinetik 1800 in rear.
Big 3.
(H/O Alt Soon to come)
Kicker ZX200.4
Kicker 6.5 doors (blown)
RF 6.5 comp set (soon to come)
1 run of Stinger 1/0 guage (soon to be 3)
All of the above is all gone
Currently own a 2000 Pontiac Trans Am WS6
No audio components.
Voltage regulator gone bad???
2000 GMC sierra 1500 ext cab
KMC XD Spy series rims
Front doors Fosgate punch 6 1/2's stock tweets
Rear doors Fosgate power 4x6's
Probox 10 and box under rear seat
Rockford fosgate R-500 Prime series amp (537 rms)
4 gauge wiring
if u unhooked the battery for a while n then hooked it back up the alt will bost the voltage till the battery is charged again
this is how u can tell if a battery is charged or not from a battery charger, if the voltage goes from 15.xvolt to around 12.0-12.6 WHILE STILL HOOKED UP the battery is charged
i had not known this till i at playin around with my truck and i had both my batterys unhooked n when i got done with my big three my voltage was at like 15.8v then went down to 14.4 or so
its normal, its the internal voltage regulator that does this, i just wished i knew how to tap into it n set it to w/e i wanted to n leave it at that
anyways hope this answeres ur question
and if ur voltage doesnt go back down to around 14v after a while ied have it checked cause the voltage regulator might be bad n could burn up ur alt if u aint carefull
i kno mla moduals boost voltage n what knot too but it was made for that reason, if ur voltage doesnt go back down it might go up higher n burn up something
i think mine ran at like 15.6v for 2 days i think n then went back down to 14.4-14.8
just in cold weather let ur batterys charge good befor u start wangin on ur stereo, they tend to loose voltage due to cold climates than hot-warm
Yeah me too, external seems the only way :/
Does your alternator wire go to a fuse box under the hood then to the battery from the fuse box?
  • Who's Online   1 Member, 0 Anonymous, 1297 Guests (See full list)
