coil burning??
LoudBimmer
COME ON bro
if you dont have the electrical to power ur amp then TURN THE GAIN DOWN, this is rocket science... wire it for 1 ohm and set the gain for 6-700w @1ohm end of story
whether you have it wired for 1 ohm or 2 ohm, YOU dictate how much power the sub gets by the GAIN setting
ur sub isnt going to magically get 1200w if you dont set ur gain for that
i rewired my sub and it came out to 1.3 ohms load.
there you go. 1 ohm load right there. its never gonna be perfect. now go tune your gains like we all have said 100 times
edit: honestly man, it doesnt take this long to diagnose a problem and fix it. do what we tell you and your stuff will last
set your voltage to 24.5
maybe 26
you still have a LOT to learn man
ur lucky you got that DC woofer haha that coil should have exploded
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
and decaf, it IS rocket science lol.
lol, i noticed that... it was suppose to say "isnt"
this is true, exploshun!! lulz
please tell me u checked each voicecoils ohm before wiring them together to get ur 1.3
hopefully u didnt do any damage to the one coil hooked up
otherwise just insert ur wattage into this equation
R= rms wattage
(R x 1.3ohm)sqrt = voltage to set gain at
example
(700w x 1.3ohm)sqrt = 30.1v
Is It really 1.3 or 1 even because that will change the voltage amount when setting the gain iam going to say. 1even because your meter is off .3 I could be wrong but I doubt it.
TEAM GROUNDPOUNDERS INC.
156.5 OUT THE TRUNK OF A 95 CADDY
W/1 SUB & 2AMPs
score done on a termlab mic in the kick
on the dash sealed was 154
internal DMM resistance couldve added a few tenths to the resistive load.
touch the 2 dmm leads together and see what number you get. take that number and subtract it from 1.3 or w/e your subs resistance is through the meter.
R= rms wattage
example
each coil is 2 ohms. so 600w x 1.3ohm= ~27V.
dont do 1.3 ohms yet. your not 100% sure its exactly htat.
do what i said in post 96 then redo the math
each coil is 2 ohms on the dmm?
or they are called 2 ohm voicecoils?
but yes that would be correct (27.9v)
mine did the same thing, i have a lvl 3 15 so i think its just extra glue mine grew out of smelling like that on a sundown 1000d
1998 4dr blazer
Alpine CDA 9884 head unit
DC lvl 3 15"
3.7 CU FT box (without displacement) tuned to 36.9
1/0 welding cable
Sundown Sae-1000D at 1 ohm
Kicker 4x6 mids and highs in dash
Hifonics Zeus 6.5 mids and highs in front doors
  • Who's Online   0 Members, 0 Anonymous, 1045 Guests (See full list)
