coil burning??
LoudBimmer
it could be your box design as well.
most likely your amp settings but how many cubic feet and square inches of port do you have?
5.3 C.F. after sub and port disp.
P.S. all the setting on my H/U are off
how many square inches of port?
easiest way to eliminate clipping real fast is turn bass all the way negative on your headunit and turn off the loud feature
then play the same volume and song and see if it goes away.
also you might be playing a clipped ass song (don't try to tune your amp with a gucci mane song)
edit:
also what is your voltage dropping to when playing at your max listening volume?
voltage drop causes clipping as well
port is .9 C.F.
i'm using 50 hz test tone.
after playing young jeezy-white girl and gorrila zoe-money man it started to smell.
no more then 11.5V, but it stay's at about 12.2-12.8
yes it was
was car running when you set the amp?
when me and derek ( fox_racin ) set our amps we always did it with the car off.. then go for a ride and listen.. you could her eit poping and clipping a bit. come home and cheak it again with the car off and its the same.. wtf.. fire up the car and it was up at 78V instead of the 77V and yes it makes that much of a diffrence.
is it at 2 or 1 ohms?
what coils are you running?
Eclipse cd7000
i say its becasue of your voltage.... get it up higher and you shoul dbe fine
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
wtf, it's burning again and all i did,is i changed power wire to 1/0 gauge and ground to 4 gauge. before it was 4 gauge for power and 8 gauge for ground.
wat? :01nocomment8so:
they need to be equal sized. ground is as important as power. make sure you fix this man...
Team Bass-Hz
  • Who's Online   0 Members, 0 Anonymous, 1040 Guests (See full list)
