ptcary Posted December 22, 2009 Report Posted December 22, 2009 I am trying to help a friend on the PT forums, he is seeing a voltage drop on a ~800 watt RMS setup in his PT. His sub amp is intermittently shutting off at high volume when it drops as low as 11.5v. (PTs are regulated to 13.6v factory). How can he tell if it is an alternator vs a battery problem, assuming the amp is protecting itself from low voltage? PTCary 2003 SMD PT Cruiser 2011 Honda CBR 250R 2010 Mazda 3i Sport MY BUILD LOG
andym85 Posted December 22, 2009 Report Posted December 22, 2009 sounds like some loose wiring or a partially bad fuse....i would check the voltage at the battery and also at the amp i likes me some audio stuff...
