95Altima Posted December 22, 2009 Report Posted December 22, 2009 Okay. So I have a completely stock battery (no need to upgrade just yet), but it seems to have a connection issue. At times, when I try to start the car, the car attempts to start, then everything dies. I pop the hood, lift the battery and it starts working again. What is likely the problem? Is the battery somehow being drained? Do I just need a new battery? Thank you in advance! 1 15" Planet Audio Big Bang AP30001D Sony Headunit 1/0 Wiring
Mosin Posted December 22, 2009 Report Posted December 22, 2009 Are you 100% sure your connections at the battery are 100% tight and secure? Derp.
abervintageman42 Posted December 22, 2009 Report Posted December 22, 2009 Okay.So I have a completely stock battery (no need to upgrade just yet), but it seems to have a connection issue. At times, when I try to start the car, the car attempts to start, then everything dies. I pop the hood, lift the battery and it starts working again. What is likely the problem? Is the battery somehow being drained? Do I just need a new battery? Thank you in advance! my old truck did that, turns out the connections were loose Are you 100% sure your connections at the battery are 100% tight and secure? this
95Altima Posted December 22, 2009 Author Report Posted December 22, 2009 Are you 100% sure your connections at the battery are 100% tight and secure? Baha... Probably not. The terminals themselves are pretty corroded, that could be the issue. I should get it checked out at the same time as I get my insane belt-related squeal checked out. 1 15" Planet Audio Big Bang AP30001D Sony Headunit 1/0 Wiring
Mosin Posted December 22, 2009 Report Posted December 22, 2009 Well there you go, problem solved. Get new terminals. A new batt would be a plus if yours is old also. Derp.
95Altima Posted December 22, 2009 Author Report Posted December 22, 2009 Thanks for your help! Now I'm split. I do need a new car -- maybe I should just live with this inconsistent problem until I get a new car. 1 15" Planet Audio Big Bang AP30001D Sony Headunit 1/0 Wiring
