My friend burned up a Alpine SWR-1222 and just gave it to me. I took it apart just to look at it. The coil is shot, but I want to know if there is any way I can get a new coil for it. I know it'll probably be real hard to build my own. What can I do to bring this back to life? It would be cool to just have around for fun.
My Youtube Page. Check it out
The "SAV" - Sub-aural Assault Vehicle
Kenwood eXcelon KDC-X993
Image Dynamics CTX 6.5" Components
Q-logic 6.5" kick pods
CDT 6.5" CL-E6NEO Front door Midbass
Kicker ZX350.4
Knukonceptz SS Karma 4 channel 6m RCA
Fi Q 18" w/ brushed aluminum dust cap
7cu ft. ported box tuned to 28hz
Sundown SAZ-1000D
Iraggi 240 amp Amputator Alt
Big 3 in Monster 1/0awg
Second Skin Damplifier Lite on roof and front doors
forevrbumpn used to have type r coils back when he was sellin coils look him up
Cool, thanks.
Kicker ZX350.4
Sundown SAZ-1000D
Pretty much pointless to recone $100 woofer.
Pioneer AVIC-N2
Im reconing a Type R now, but the recone kit I got used different spiders, and a coil about 1/8th to short to actually do a good glue bead, and keep the coil gap height right,
so Iam changing the frame out. When done, it will be better than a $100 woofer. This Type R Im working on will have a common 12 spoke, 12" frame, and look cooler, and more functional than the factory design. I will post a pic tomorrow when Im done
back to work now...
back to work now...
I'm excited to see how this looks and the functionality of it over the OEM design. I'm always wanted to do some sort of a franken woofer using my blown 15" R I have... Do they use standard coil sizes and are u having to tap holes to fit the 12 spoke on??
Pioneer AVIC-N2
But that would be useless...
Kicker ZX350.4
Sundown SAZ-1000D
Haha Sorry marlo, but he does have a point. You ended up contradicting your first statement. ;)
What I mean was.... It's not pointless to use the motor in a different design but to recone the actual woofer using the original basket + OEM recone itself IMO would be pointless. You're gonna spend at least $100 for the recone, then factor in glue, labor, etc and it will cost much more than a new woofer would.
Pioneer AVIC-N2
I will take pics when I get home, 530am, and Im still at the office
I just swapped out the frame, and used a tighter spider
This is the Type R 12" coil is a undersized 2"- 1.94" to be exact, and the damn 15" is a hard as hell to find 2.582" coil
Why cant they stay standard?
The type R 12" motor sucks balls, it had a 5 hole pattern, and I needed to use my router to notch out the frame I used so that the 5 hole pattern would catch on to the frame, and lock in place, over drilling thru the frame with a new set of holes- couldnt work due to the hole pattern being like 4" on the motor, and the 4" opening on the frame- wasnt that easy of a mock up
