bigjsurdaddy Posted December 24, 2009 Report Posted December 24, 2009 I was looking for some 1/0 gauge wire. i wanted to get the knu stuff but the flex is to much for my blood but the klmx looks nice. i read that it's copper clad aluminum, anyone used the stuff or know someone that has. Any help would be appreciated. Quote
TeejayBee Posted December 24, 2009 Report Posted December 24, 2009 http://www.knukonceptz.com/productDetail.cfm?prodID=KFX-PK0 Just saying its only $90 Quote
AI James Posted December 24, 2009 Report Posted December 24, 2009 (edited) go with some copper based stuff rather then be cheap and get cca Edited December 24, 2009 by Accordman Quote
bigjsurdaddy Posted December 24, 2009 Author Report Posted December 24, 2009 go with some copper based stuff rather then be cheap and get cca what's cca again. i forgot. Quote
bigjsurdaddy Posted December 24, 2009 Author Report Posted December 24, 2009 http://www.knukonceptz.com/productDetail.cfm?prodID=KFX-PK0Just saying its only $90 that's not enough wire. i got to do the big 3 upgrade and go from the front bat to the back then to a distibution block and then to two amps. Quote
J00bles Posted December 24, 2009 Report Posted December 24, 2009 (edited) what's cca again. i forgot. i think he means stay away from CCA, as it is copper clad aluminum. you want something that is OFC, as its oxygen free copper. also, what kind of power are you running? Edited December 24, 2009 by J00bles Quote 8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee Click to see J00bles' Youtube Channel
white4d96 Posted December 24, 2009 Report Posted December 24, 2009 what's cca again. i forgot. copper clad aluminum. Basically its aluminum with a copper plating on it. Quote Too many projects, too little time...
kl0wn Posted December 24, 2009 Report Posted December 24, 2009 what's cca again. i forgot. Copper Clad Aluminum Quote 06 Mini Cooper S Sundown, SoundQubed Cadence, XS Power 151s Sealed 155s Outlaw Windshield @ 37hz
bigjsurdaddy Posted December 24, 2009 Author Report Posted December 24, 2009 i think he means stay away from CCA, as it is copper clad aluminum. you want something that is OFC, as its oxygen free copper. also, what kind of power are you running? for now it will be 1 saz 1500 at 1ohm and problably a saz 100.4. later down the road i'll get another saz 1500 Quote
J00bles Posted December 24, 2009 Report Posted December 24, 2009 for now it will be 1 saz 1500 at 1ohm and problably a saz 100.4.later down the road i'll get another saz 1500 you would be fine using the KLMX for now, but once you throw over 3k watts into your system, you'll have to upgrade. may as well put the good wire in now, and not worry about it later. Quote 8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee Click to see J00bles' Youtube Channel
