Trying to fit a Double din into a 1.5 Din spot.
unless the double din is wider than the single din in their currently I don't see the problem at all. Buy some abs sheets and buiild your own kit .
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
if you cant figure out how to make it work man, good luck on getting it in there and having it stay
TEAM NEMESIS
my system
1) us amps MD3D, us amps md21
2) kicker solo x 12 in 2.7ft^3 at 37hz
Meca scores
1 xxx12" 141.8db at 40hz,
1 18 rd alpha v.2 145 db at 38hz , 2 12 orion hp 144.9 at 43hz
Refs: hollatchaboy, schrummy, nitro_freak1,Brandon15zzz,Hellbound Train
all u gotta do is get yo radio if u can find a dash kit that fits a double din radio do a few adjustments to it and itll go right in there may have to trim a little outta the dash but thats all u gotta do. holla at me if u need help man.
I know a lil about everything so dont call me Mr. Know it All.
like I said buy some abs sheets and go to it. I don't see anything that would make it difficult. It should fit right in there and you'll just make your own kit.
Do the kit first. mount the head unit up in there and see how it is without touching the bezel. is it sturdy? flimsy? flapping all over? once that is securely mounted and not looking like its going to fall out work on slowly trimming out your bezel.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Well see i just thought of a way, I build somthing that fits around the H/u and the have a piece of metal or wood that goes along the sides to hold it up and then have medal or wood thats on the front part screw into my holes that are already there
same concept as what I said. just different materials.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
its easier than ure makin it out to be man good luck wit the build tho homie like i said holla if u need help!!
exactly if you get stuck post it up. dont be afraid of it.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
What material would be suggest to use? i mean i have a buddy who is gona help but most deff if i need help ima ask i dont care bout what people gota say bout stupid questions gota learn some way
  • Who's Online   0 Members, 0 Anonymous, 372 Guests (See full list)
