tudski Posted December 29, 2009 Report Share Posted December 29, 2009 so i was driving along ht the gas a little harder cause i was inbetween 2 trucks and i didnt like it next thing i know it says check coolant temp rises smokeing but not much hotter then normal... usuall around 98-101c but now was around 111-117(highest it went) i got home poped the hood clear liquid everywere... i dont know much about engines but im guessin somethign to do with coolant ballast or radiator? Quote 1996 deville on 18" full face rims -2 gauge wire. -a2400db -RE SE-X in a 4ftc box tuned to 32hz -tview touch double din -rockford punch 6x9s(rear) -mtx 6.5(front) front and rear stage will soon be changed build log will start as soon as it aint cold! Link to comment Share on other sites More sharing options...
JEMT8 Posted December 29, 2009 Report Share Posted December 29, 2009 so i was driving along ht the gas a little harder cause i was inbetween 2 trucks and i didnt like it next thing i know it says check coolant temp rises smokeing but not much hotter then normal... usuall around 98-101c but now was around 111-117(highest it went) i got home poped the hood clear liquid everywere... i dont know much about engines but im guessin somethign to do with coolant ballast or radiator? If it was smoking and smelled of antifreeze than you definately blew a radiator line i believe. Quote formerly known as Jaylor Swift Link to comment Share on other sites More sharing options...
Andrew2944r Posted December 29, 2009 Report Share Posted December 29, 2009 thermostat Quote Team Ampere Audio Link to comment Share on other sites More sharing options...
tudski Posted December 29, 2009 Author Report Share Posted December 29, 2009 If it was smoking and smelled of antifreeze than you definately blew a radiator line i believe. yessir it smelt horrible! and might i add the car runs fine.. Quote 1996 deville on 18" full face rims -2 gauge wire. -a2400db -RE SE-X in a 4ftc box tuned to 32hz -tview touch double din -rockford punch 6x9s(rear) -mtx 6.5(front) front and rear stage will soon be changed build log will start as soon as it aint cold! Link to comment Share on other sites More sharing options...
Andrew2944r Posted December 29, 2009 Report Share Posted December 29, 2009 Thermostat more than likely needs replacing, when one goes out it will typically make the radiator overflow because of excess heat. Quote Team Ampere Audio Link to comment Share on other sites More sharing options...
JEMT8 Posted December 29, 2009 Report Share Posted December 29, 2009 yessir it smelt horrible! and might i add the car runs fine.. Check to see if any of your hoses or blown or anything. Quote formerly known as Jaylor Swift Link to comment Share on other sites More sharing options...
TeejayBee Posted December 29, 2009 Report Share Posted December 29, 2009 You just blew the radiator to your coolant i used to do to that with my 91 cutlass i replaced it atleast three times b.c it was a beater car . But if it smells bad its deff coolant , that stuff is so nasty just when you drive dont step on your gas to hard and try to get it to a shop asap. -TeeJay Quote Link to comment Share on other sites More sharing options...
tudski Posted December 29, 2009 Author Report Share Posted December 29, 2009 Check to see if any of your hoses or blown or anything. its night right now cant do much... but lets say its either of the 2 thermostat or just a hose how much do u think the repair would be? Quote 1996 deville on 18" full face rims -2 gauge wire. -a2400db -RE SE-X in a 4ftc box tuned to 32hz -tview touch double din -rockford punch 6x9s(rear) -mtx 6.5(front) front and rear stage will soon be changed build log will start as soon as it aint cold! Link to comment Share on other sites More sharing options...
JEMT8 Posted December 29, 2009 Report Share Posted December 29, 2009 Thermostat more than likely needs replacing, when one goes out it will typically make the radiator overflow because of excess heat. That too. I've seen it happen on a tractor before. Quote formerly known as Jaylor Swift Link to comment Share on other sites More sharing options...
will77530 Posted December 29, 2009 Report Share Posted December 29, 2009 could be water pump too. when the car is cool open the radiater cap start the car and see if you can see fluid moving Quote Link to comment Share on other sites More sharing options...
