an ohm is a measure of electrical resistance. soo 1 ohm is less than 4 ohms therefore has less resistance and the amp will put out more power at 1 ohm than 4
R.I.P '01 blazer you treated my ears well until your transmission blew up.
New Project
[top secret]
149.0 db on music driver window open; so close
I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean....
I swear... sometimes I wish I was retarded so I could just agree with everyone x.
This is very well put
:clapping:
2000 GMC sierra 1500 ext cab
KMC XD Spy series rims
Front doors Fosgate punch 6 1/2's stock tweets
Rear doors Fosgate power 4x6's
Probox 10 and box under rear seat
Rockford fosgate R-500 Prime series amp (537 rms)
4 gauge wiring
thank you very much, and as far as alternators and batteries are concerned, do you have your new amp in yet? if so how bads your voltage dropping? i would start with a battery in the back and go from there. a kinetic or xs power somewhwewe around 12 or 1800. deka also makes very good batteries.
New Project
[top secret]
not yet all i got is a little power acoustik 1200 gothic series. it says 900 at 2 ohms but i think it's more like 5 or 600.
i wanted a d3400 for the front and a d975 in the back with a 240 amp alt. if my math is right that should just about do me.
when i can find some good 1/0 wire kinda cheap i will do the big three upgrade. i know i should have done that already but i haven't got around to it.
do you guys think copper clad aluminum wire is ok for what i got or should i stick with oxygen free copper?
no no no no. the amp puts out more power at a lower resistance, yes, but it becomes much less efficienct.
so the saz1500 is something like 80% efficient at 4ohm. at 1ohm its closer to 65% efficient and takes a lot more electrical to be able to support it. so now your trippling the power output and your amp is 15% less efficient so itll take a ton more electrical to keep up.
eh, my numbers were a little off but here is a bunch of info for this question. just look at the test results.
http://audioforum.termpro.com/cgi-bin/ubb/...20;t=013151;p=0
I can vouch for everything skittles said, indeed amps get LESS efficient at lower ohms, but put out more power.
Most amp efficiencies are rated at 4 ohms, say 86%. At 1 ohm this same amp might only be 70% efficient.
2001 Chevy Blazer
(2) SAZ-3000Ds
(2) custom 18" Madmax subs in a second row wall
Rockford 600-4
Pioneer PRS components
Pioneer P800PRS deck
