quick question wheres the pos jump terminal go to?
R.I.P!
(Nov-29-2009)
92 explorer
current build
for the batt to engine block, do you just find a bolt on the engine block and put the ring terminal on that?
I know that it goes to negative, but the other end just attaches to any bolt on the engine block or what? That's the only part of the big 3 that I don't understand
