uhoh_45 Posted January 5, 2010 Report Posted January 5, 2010 so i have my laptop hooked up to my philips 5.1 and whenever i go past volume 10 (low volume) i get electrical noise and it is annoying as hell its connected via 3.5 mm headphone cable i bought it from radio shack/the source for 20$ any helps appreciated R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
qu1cks1lver56 Posted January 5, 2010 Report Posted January 5, 2010 is your laptop plugged into the wall? First Gen Xterra: Always changing DNX 690HD RF 360.3RF T3002RF T4004RF T10001bdSilver Flute 6.5"s Tang Band 1" TweetersSundown X18 in 7cubes net tuned to 32hz Trust me .25 Blows your Load.
Maxim Posted January 5, 2010 Report Posted January 5, 2010 is your laptop plugged into the wall? this if the laptops plugged in it'll make noise wtf is lolcats? I'd def get a fat hooker if i had to resort to that kinda thing. I feel like they'd be grateful and work harder. Also its more bang for my buck, more real estate for my dollar if you catch my drift. its like the Costco of streetwalkers. I was hoping for 150 . I was hoping she would let me put it in her butt
uhoh_45 Posted January 5, 2010 Author Report Posted January 5, 2010 really that simple of fix eh alright i'll try with it unplugged R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
qu1cks1lver56 Posted January 5, 2010 Report Posted January 5, 2010 most of the time only if it's a grounded plug for the charger. get a ground lift adapter and it should quit. First Gen Xterra: Always changing DNX 690HD RF 360.3RF T3002RF T4004RF T10001bdSilver Flute 6.5"s Tang Band 1" TweetersSundown X18 in 7cubes net tuned to 32hz Trust me .25 Blows your Load.
Boon Posted January 5, 2010 Report Posted January 5, 2010 It's a ground loop. 2 things you can do... 1. Snap the ground pin off your laptop's power cord (don't do this ) - you can use a ground lift adapter which amounts to the same thing, or a ground loop isolator on the cable to the receiver. 2. Star earthing. Are the laptop and the receiver plugged into the same wall point? The laptop may be using a lifted audio ground in which case you have to get a bit creative 10.x volts fo' life!
uhoh_45 Posted January 5, 2010 Author Report Posted January 5, 2010 It's a ground loop.2 things you can do... 1. Snap the ground pin off your laptop's power cord (don't do this ) - you can use a ground lift adapter which amounts to the same thing, or a ground loop isolator on the cable to the receiver. 2. Star earthing. Are the laptop and the receiver plugged into the same wall point? The laptop may be using a lifted audio ground in which case you have to get a bit creative yeah there next to each other using same surge bar.. i figured running my receiver or laptop cable to another jack would help but theres only one way to test i'll move laptop over more straighten out long 3mm cord and plug in laptop to another socket and if all else fails where can i get the isolator? R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
qu1cks1lver56 Posted January 5, 2010 Report Posted January 5, 2010 walmart carries the scosche isolators, and they actually work well. First Gen Xterra: Always changing DNX 690HD RF 360.3RF T3002RF T4004RF T10001bdSilver Flute 6.5"s Tang Band 1" TweetersSundown X18 in 7cubes net tuned to 32hz Trust me .25 Blows your Load.
uhoh_45 Posted January 5, 2010 Author Report Posted January 5, 2010 only problem with that is that it is rca to rca not headphone to headphone and i dont wanna have to go out and buy 2 more converter cords R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
