mad drunx Posted January 7, 2010 Report Posted January 7, 2010 What kind of cloth is that? And make sure your magnet's don't hit the back it look's pretty close. wunna play halo?
Mattruck1990 Posted January 7, 2010 Author Report Posted January 7, 2010 It's a cotton weave the exact name i'm not sure but it's got a really nice stretch to it and holds a shape fairly well doesn't take too much resin to saturate it... it seems really close to pool table felt only thiner and the pioneer 6.5's are really shallow so they are fine but the main thing that would hit is the Head Unit but i checked and it cleared 1993 Honda Civic LX Kenwood KDC-MP342U Head Unit Alpine MRP-250 Alpine MRP-500 Dual Alpine Type E-12's Blaupunkt 2-way Coaxial all 4 doors Sealed Box
Mattruck1990 Posted January 7, 2010 Author Report Posted January 7, 2010 The reason i think that it's so blotchy is cause the resin was really thick and i think i mixed in a little too much hardener but almost all the area got a little resin on it and now this weekend i'll start getting the fiberglass on there With Resin and equipment Back you can really tell the unevenness (aah first project i still will enjoy it cause it does sound good) Side where i failed to get resin on a spot Top View Other Side view Yeah i probably should of worked a little harder to get it all even but oh well it serves it's purpose and still looks cool, now what color do you guys think between Metallic Blue Metallic Red Light Green Gloss Black I'm leaning toward the Blue like the backlight but open to any other suggestions 1993 Honda Civic LX Kenwood KDC-MP342U Head Unit Alpine MRP-250 Alpine MRP-500 Dual Alpine Type E-12's Blaupunkt 2-way Coaxial all 4 doors Sealed Box
mad drunx Posted January 7, 2010 Report Posted January 7, 2010 Yeah i probably should of worked a little harder to get it all even but oh well it serves it's purpose and still looks cool, now what color do you guys think between Metallic Blue Metallic Red Light Green Gloss Black I'm leaning toward the Blue like the backlight but open to any other suggestions Are you planning on painting it? if so that takes alot of time,sanding,and a little bit more experience to make it look good.But if you do then black.When you resin don't be shy,it's better to have too much than not enough.That stuff look's pretty thin so I would put a few extra layer's of fiberglass.And nice job . wunna play halo?
tehbert0 Posted January 7, 2010 Report Posted January 7, 2010 haha my friend made this in thesummer =] http://motorcitydesignsaudio.com
ryde2idie Posted January 7, 2010 Report Posted January 7, 2010 Are you planning on painting it? if so that takes alot of time,sanding,and a little bit more experience to make it look good.But if you do then black.When you resin don't be shy,it's better to have too much than not enough.That stuff look's pretty thin so I would put a few extra layer's of fiberglass.And nice job . When you put an excessive amount of resin on it begins to "pool" in certain spots and what i mean is the resin works with gravity to make a perfectly level flat spot on anything it builds up on (so if you have very detailed lines or dips in your sculpture the resin will level them out while your not looking). Id say go over it a little with 80 grit sand paper just to scuff it up then clean it to give the next coat of resin something to adhere to. One more word of advice to ya man, be creative. Not sayin your piece isnt, but in the world of fiberglass the possibilitys are endless and that is a beautiful thing. Quote
Mattruck1990 Posted January 8, 2010 Author Report Posted January 8, 2010 Yeah i just got back from talking with some of my friends at ABC warehouse and they liked it and had some suggestions. I am going to re cut the front and pull out the head unit and angle it up which will look real cool when done and i also got some freebe's cause they didn't like the look of the speaker edge a couple of polk DB 6.5 speaker covers. But the tweeters didn't line up (the top one) So i broke out the jig saw And what remained Put on the speaker and doesn't look too bad at all With both covers cut and on I am going to work this weekend to pull out the head unit and angle it some odd direction Angled up and possibly off level tilted to the side or something 1993 Honda Civic LX Kenwood KDC-MP342U Head Unit Alpine MRP-250 Alpine MRP-500 Dual Alpine Type E-12's Blaupunkt 2-way Coaxial all 4 doors Sealed Box
Mattruck1990 Posted January 8, 2010 Author Report Posted January 8, 2010 Well i couldn't resist and i started to tilt the head unit... :01nocomment8so: didn't get any pics of the under parts but overall i think it will work and doesn't look half bad. It does look better in person you get a better perspective of the angle and lines. Front View Side Other side i have to give props though to matt for the idea to use the Polk grills and Nate for the idea of how to cut them I'll be resining the new part in the next day or two and hopefully getting a layer of actual glass on it also 1993 Honda Civic LX Kenwood KDC-MP342U Head Unit Alpine MRP-250 Alpine MRP-500 Dual Alpine Type E-12's Blaupunkt 2-way Coaxial all 4 doors Sealed Box
Gotloud555 Posted January 8, 2010 Report Posted January 8, 2010 Look alright but you still need to put more resin on it. Every parts on the fleech must be darken and hard.
Dozier Posted January 14, 2010 Report Posted January 14, 2010 Be sure to add several layers of mat on that. Light oz mat. It looks a little flimsy. It will all be the same dark color once it is all evenly coated with resin. www.AlabamaDrift.com04 Silverado in the works
