How does this look?
Percy
facepalm
u need at least the ports width in clearance... so the end of ur port wall needs to be at least 4.25" from anything
so u would bend the port
im going to bed, someone pick up where i left off
the port would go 21.25 back, then turn
wow no one else is helping, lol
so percy do u understand what im saying
put in 21.25 for ur port length, that is as long as it can be without turning like in the pic i did
facepalm
dont be using my enclosure plans as an example! jkjk
2010 Silverado
18" DC XL 18
DC 2k
XS Power Batts
lol, i hunted for a pic without dimensions that give away the box, it was hard!
good eye
ya i get it decaf, i appreciate the help, since the original port opening is 4.25 inches, then i need at least 4.25 inches for the opening inside? so theres no cancellation or whatever its called? so if i make the port length 21.25 and make an L of at least 4.25??
when u put port length into that box calculator is means the total port length, not the length for the piece of wood
u should do
20*32*27 external
6.76cuft@34hz
5" wide port... total port length is 23"
(actual wood would be 20.5)
13.67sqin/cuft
much better, u need more port anyways
no L needed
use dowel rods for bracing top to bottom, side to port wall and front to back
u should do
20*32*27 external
6.76cuft@34hz
13.67sqin/cuft
no L needed
cool, thanks man, lemme plug those in real quick..
is 13 sq in of port per cu ft enough?
  • Who's Online   0 Members, 0 Anonymous, 573 Guests (See full list)
