I plan on getting 2- t400.4's (new model) and 2- t4000.1's and was curious about a couple things, first if one of the t4k's has a higher output wattage than the other which do i make the master? Second between the t400.4's if i run one at 2 ohms and the other at 4 ohm can they also be interconnected together via rca's since they have a different impedance?
I needed a visual. is this correct? Another thing with the t4000's if they are hooked up like this will i only need to use 1 bass knob.
i forgot the output to input on the t4k's
use one bass knob on the master amp
on the 4 channel or the mono
so the both t4k's need the gains set too? or just the master?
the master amp is the only gain you need to set for the t4k's
Wouldnt be thehoe92 without teh purple
set gains on master and the slave is for fine tunein
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
Negative... with bd-sync the master controls the gain for the slave. Which is why you use the slightly less powerful amp as the master ;)
10.x volts fo' life!
  • Who's Online   0 Members, 1 Anonymous (See full list)
