Alright here are the pics for the passenger door panel. First I cut a lot of little holes
Then I went in and snipped the connectors with tin snips
There is a wiring harness right behind a section where I drilled through, had to be carefull
Then I put a double layer of electrical tape down
Edited by CJtech323
sweet ride you got there with those bostons should sound sweet to
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
  • 4 weeks later...
Big Update, everything is installed and working! Right now I am just tuning the crossover between the sub and components and also tuning the comps. My trunk is a rats nest right now, but Im in the process of building a new box/ amp rack to fit all this equipment in my limited trunk :rolleyes: Here are some pics, I'll upload some more later.
I used the stock 16ga speaker wire for the woofers
And then I applied to Second Skin. I kept on putting down layers in rattling spot until there was no more resonance, up to three layers at some spots. But now my doors are dead silent
Didn't take any pics of the building of my door pods, but they are covered in layers of rustoleom for moisture protection. Here is the drivers side
And the passengers side
The tweeters are mounted in the stock locations, aimed slightly up and towards the opposite seats (passenger tweet aimed towards driver seat and vise versa). This gives a great image, voices sound centered and coming from the bottom center of the windshield. I do have a little alternator whine problem, but thats just because I need to work out the ground. Overall I am highly pleased with the bostons, I ended up putting the tweeters at -4db because they were to profound at first, but they sound excellent now.
