Hello everybody!!!! I just bought my SAX-100.4 a couple of weeks ago from *** and just got to installing it and i am upset that i can't get a good audio signal to come out. The audio sounds very weak and cuts in and out very rapidly at low volumes till i turn it up a little over half of the volume does the audio sounds full and a little bit cleaner even though it has some sound kind of like static. i have to turn it up pretty loud for it to have pretty clean sound with nice midbass. but anything around half or lower sound nasty!!!!!!!I tried the cleanest music i have and nothing sounds good at all! i cant even turn my car off because if i do the audio gets even worse and only plays good when very loud(which i don't do but for a few seconds just to see how it sounded)
Let me add that i have tried 2 different head units and gone all over my connections more than a few times
My car is a 1997 Nissan Maxima GXE i used a run of positive and negative 4awg wire from the battery to the
amp i am using DB-Link rca wires. the amp is getting 12.62v with the car off and 14.11v at idle with everything off and 14.06v with headlights and heater set to high.
Thanks in advance!!!!
Jesus Ugalde
Dallas,TX
what speakers are you powering? Try emailing Jacob. this is the best way to get a hold of him. You are in good hands with him :)
Eclipse cd7000
why not try finding a ground closer to the amp? i thought the best grounds are no longer than like a foot is that myth or what?
06 Impala SS
Kenwood Excelon DDX593
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
Mechman 320a Alt. w/ Big 3
Lots of Second Skin Damplifier
Under Construction for 2017
Right now im using some Alpine SPG-17C2's
Edited by oc_wicked
Have you actually ran a different RCA cable ?
Well i have 2 pairs one for the front and one for the back i dont think i got 2 bad rca cables but i guess ill try that since im getting the same nasty sound on all 4 speakers
  • Who's Online   0 Members, 0 Anonymous, 1633 Guests (See full list)
