I've heard 2 different things and I just want to make sure of this for the Big 3.
Do I connect battery negative to just a random bolt on the engine block
-OR-
Do I connect the engine block to a ground?
I don't want to do the wrong thing and look like a douche bag
Thanks,
Sam
-OR-
Thanks,
Sam
look for a wire that runs from the chassis to the engien block that will be your ground, just put 0 guage where that wire runs, dont replace, just add onto
-OR-
Thanks,
Sam
i just did my big 3 and i grounded the engine block to the frame and the negetive battery terminal to the body i believe this is the correct way.
99 suburban
20" boss motorsport wheels
big 3 installed (thanks Iraggi)
alpine 9886 deck
kenwood 11 band eq
fosgate t5002 amp running sub
kenwood ps200 amp running components
jl xr components in front doors
jl xr 6.5 in rear doors
jl in rear roof
1 FI Q 18" with bp
enclosure 8 cubes 138 sq" port 34hz
Iraggi 220 ho alt
(RF 1500bd coming soon)
Oh believe me I looked! Every single wire is in protective tubing and runs under the engine and all over the place
so you just did engine block right to a ground and put the SAME ground to the negative?
no on mine i ran the wire from the block to the frame of the truck and then ran another wire from the negetive battery terminal to the body of the truck.
ground from the battery negetive
this is the frame ground to the engine block
99 suburban
alpine 9886 deck
kenwood 11 band eq
jl in rear roof
1 FI Q 18" with bp
Iraggi 220 ho alt
i would have done the same ground to the block but my 3rd wire was too short, i dont think it would hurt anything to hook both to the block and ground accordingly.
99 suburban
alpine 9886 deck
kenwood 11 band eq
jl in rear roof
1 FI Q 18" with bp
Iraggi 220 ho alt
alright cool. so just find a bolt I can use for the engine block, and another bolt on the frame, and call it a day?
Yeah, just make sure you have 1 ground from the block to battery.. one from battery to chassis. An I have heard of a few people grounding the alternator to the chassis too. I don't know if the last one is completely necessary though.
1993 Chevrolet SWB Pickup
Viper 791XV
Primer Stage
5/8 Static Drop
Kinetik HC1800
Big 3 Knu Flex 0
Team Tex Flex
  • Who's Online   0 Members, 0 Anonymous, 7042 Guests (See full list)
