TeejayBee Posted January 11, 2010 Report Posted January 11, 2010 okay so i just got back from work and my computer wont turn on? ........ its been in perfict shape but now it wont turn on i was on it right before i left for work four hours ago and no problems....... i unplugged everthing but my power cord nothing happend then but there is a green light blinking on and off on the back of my tower ... my computer is a compaq SR1820NX if anyone can help please i need it
MrSkippyJ Posted January 11, 2010 Report Posted January 11, 2010 okay so i just got back from work and my computer wont turn on? ........ its been in perfict shape but now it wont turn on i was on it right before i left for work four hours ago and no problems....... i unplugged everthing but my power cord nothing happend then but there is a green light blinking on and off on the back of my tower ... my computer is a compaq SR1820NX if anyone can help please i need it I don't know too much about computers but just from that I would check my power supply and my bios battery. Again, I don't know much about them so either of those could be totally wrong. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Neel Posted January 11, 2010 Report Posted January 11, 2010 sounds like a bad power supply, how comfortable are you with opening up the computer? Too Much Stuff to list .
TeejayBee Posted January 11, 2010 Author Report Posted January 11, 2010 i have it opend up already ive tryed a five different outlets i know a good amount about computers but this shit is redic
MrSkippyJ Posted January 11, 2010 Report Posted January 11, 2010 i have it opend up already ive tryed a five different outlets i know a good amount about computers but this shit is redic Find a known good power supply and try that. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Guest Posted January 11, 2010 Report Posted January 11, 2010 usually there is a light that turns on on the motherboard itself when you plug the cord into the power supply, even if the computer is shut off, the little LED should be on. on my computer it is green and a few others i have seen are green also. its generally near the CPU heatsink and the dedicated ports.
TeejayBee Posted January 11, 2010 Author Report Posted January 11, 2010 all our outlets are good supplies but kranny there is a light on the back that is flashing green with the power cord in the slot and with it out of the power spot... but its on the back no lights on the inside
Guest Posted January 11, 2010 Report Posted January 11, 2010 heres a nice PSU i found by googleing your computer model and power supply at the end of it. not bad for $45 IMO http://www.atxpowersupplies.com/630-watt-p...630WPS-SR1820NX $30 more expensive on ebay? http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...4=263602_263622 edit: this is the absolutely last step if you cant find a solution
Neel Posted January 11, 2010 Report Posted January 11, 2010 Alright so now that you have it open, grab a paper clip and a voltmeter. Remove the main 24 or 20 pin connector from the motherboard. Once removed, find the green wire, insert the paperclip into the green wire and then stick it into any prong with a black wire or even the chassis of the computer. The green wire is the "remote" to the power supply and when its grounded the power supply will turn on. So do that and then with your volt meter , prong any 4 pin molex connector. So on your voltmeter , put your negative prong anywhere on the chassis of the computer and put the positive prong in to a yellow wire, it will read around 12v. Also red wire will read around 5v. If you get no readings .. or get some weird readings you have a bad power supply. Not a big deal, just go to your local computer store and pick up a new one and then stick it in and see what happens!! Too Much Stuff to list .
Guest Posted January 11, 2010 Report Posted January 11, 2010 http://forums.techguy.org/multimedia/69287...n-flashing.html i just read that you can smell the back of your power supply (the fan outlet, make sure not to inhale dust lol) and smell for electrical burning. i assume it would be similar to a sub coil heating up
