ben29555 Posted January 11, 2010 Report Share Posted January 11, 2010 fist is their a box calculator that can do odd shapes like this? http://s93.photobucket.com/albums/l59/00s-...nt=DSC02239.jpg and using this calculator http://www.psp-inc.com/tools.html for aero ports say i have a 7 cube box tuned to 32 hz with 2 6" aeros it says 17.8 long but is that each port or do i divide that by 2 since their 2 ports making each 8.9 long also are large ports like 8" ports not able to play music because the only time i see them is in burp boxes thnaks edit: forgot to add how do i know the internal volume remaining after i put the ports in the box or is that calculator only for external aeros? My Build Log loud bass songs Link to comment Share on other sites More sharing options...
ben29555 Posted January 11, 2010 Author Report Share Posted January 11, 2010 bbump My Build Log loud bass songs Link to comment Share on other sites More sharing options...
Boon Posted January 11, 2010 Report Share Posted January 11, 2010 1. No. Pen and paper required. 2. That length per port 3. Sure they can play music. They just cost heaps and if you need that much port area in anything other than a burp car you may as well just use a slot port 4. Calculate the volume of the port then subtract it from the volume of the box... 10.x volts fo' life! Link to comment Share on other sites More sharing options...
ben29555 Posted January 11, 2010 Author Report Share Posted January 11, 2010 1. No. Pen and paper required.2. That length per port 3. Sure they can play music. They just cost heaps and if you need that much port area in anything other than a burp car you may as well just use a slot port 4. Calculate the volume of the port then subtract it from the volume of the box... will an 8" aero be good for 6 cubes after displacement? how do you calculate the volume of the port? and will puting it in the box change the tuning from what i originally wanted My Build Log loud bass songs Link to comment Share on other sites More sharing options...
