What happens if you type an m at that point, and what happens if you type another character at that point?
that^
*edit with that b! command it makes the first question come up again once the second is answered correctly
Edited by IH8PunkRok
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
change the while statement to b != 'm' instead of b== 'all the letters'.
When you input the m, the program should go back and ask you to input the opposite of 666 again, since 999 is less than 1000. It does not like the condition of that while statement.
I thought you had to say while (b=='a' || b=='b' || b=='c' . . .etc. || is the OR statement.
change it to b != 'm' and run it.
Wish I had a C compiler.
Brian
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
i believe the program im using was free. its called bloodshed dev-c++
it did what you said it would
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
type 999 for the number, then m for the letter, then type in 555 for the number. Should ask for the number again without anything about the letter. When it does, type 1001.
Want to see what the first loop does and if the program will actually end.
Edited by bkolfo4
Current system:
Previous systems:
did that^ and the program ended. just shut itself
btw thanks for the help man
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
did you type 999 the first time or 666? I messed up when typing.
Current system:
Previous systems:
If you do not type 999 the first time, it should say incorrect and ask again as long as the number you typed was below 1000. . .anything over 1000 should end the program.
Current system:
Previous systems:
i typed 999 the first time. i figured the 666 was a typo
but yea when i typed 1001 it ended
the only thing is it will ask the second question once and not wait for a response before giving away the incorrect answer response
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
It is buffering the new line when you hit enter after typing 999.
Make this change and try it:
if (a==999) {
printf("\nCorrect\n");
printf("Next Question\n");
printf("\n");
do {
scanf("%c" , &B);
printf("\nThe 13th letter of the alphabet is:");
scanf("%c" , &B);
if (b=='m') {
Edited by bkolfo4
Current system:
Previous systems:
sorry, add it here:
if (a==999) {
printf("\n");
do {
scanf("%c" , &B);
scanf("%c" , &B);
if (b=='m') {
In the other position, it will only work one time - it will not work the second time if you input the wrong letter.
Current system:
Previous systems:
