songs wont play on itunes
so i recently moved all my songs from my old computer tomy new one usimg my ipod, well i thought it was all good but i didnt test t. now the songs wont play, the error measage im getting is the song "could not be played because the original file could not be found. would you like to locate it" it says this for every song
R.I.P '01 blazer you treated my ears well until your transmission blew up.
New Project
[top secret]
149.0 db on music driver window open; so close
I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean....
I swear... sometimes I wish I was retarded so I could just agree with everyone x.
Did you double click the songs, play them, and THEN move them to a different location? Because if you download a song, and let's say you keep it in your "Downloads" file and play it from there. If you go and move the song a week later to a different file, try to play it through iTunes, you will get that exact message.
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
just find the file on your comp and click play with itunes you will have to do it manually i have to do that every now and then when i get a lot of music put into itunes
Pioneer DEH-P3000IB head unit
Rockford T1000.1bd
Two AQ SDC 2.5 12s
My build log.
http://www.stevemeadedesigns.com/board/topic/84319-darthballsy1s-04-ford-ranger-video-build-log/
you could re-import them into the library i think
but if you are not completely set on using itunes id suggst trying winamp
it is much less concerned with what media player you send songs to or what computer you put songs on
and it will transfer to anything. maybe not as fast but its still good
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
what you do is put all the songs from ur ipod in a folder named music or w/e u want then put all the songs there then take the songs from the folder and put them in itunes
do i need to take them directly from my ipod or can i move them from itunes into another folfer?
New Project
[top secret]
ok, i accidently deleted that folder. oops. thanjks guys
New Project
[top secret]
it also helps if you wanna switch comps or whatever to go to your itunes folder click on ipod and save your playlist
it saved my ass switching over computers i didnt have to redo my playlist which took couple hours to start up in first place (every artist has a folder with there cds being the subfolder for 10,000 songs)
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   1 Member, 0 Anonymous, 1403 Guests (See full list)
