I got some questions about my new setup!
First off with what I currently have: I have 2 12 inch VC2's rated at 500 watts RMS with a Diamond Audio 600.1 pushing them. I am gonna be getting two more subs of the same and need a second amp to push them. The subs are 4 ohm DVC, so all 4 together will only wire down to 2 ohms. Namosh is gonna build the box for me and its gonna have all 4 subs facing up in a common enclosure with one port. I have been looking at sonicelectronics.com and they have a RF Punch BD1000 on there for $400. So then what I would do is put the 600 watt amp on the two subs on the left and the 1000 watt amp on the two subs on the right.
My questions are: Will it sound off when 2 subs are getting 600 watts and the other 2 are getting 1000? Should I just find a new amp that pushes between 1500-2000 watts at 2 ohms and put all 4 subs on it? Does anyone have a similar setup and if so how does it sound?
Kenwood Excelon KDX-693 Head Unit
Kinetik HC600
Powerbass 6.75's in front doors
Powerbass 6.75's in rear deck
Powerbass 1000.1D
Powerbass 400.4
2 SA-12 inch Sundown Audio Subs
0 gauge Power Wire and Big 3
Custom Amp Rack
Code Alarm with remote start
Stinger Digital Volt Meter
My build log http://www.stevemeadedesigns.com/board/topic/51869-1996-chevy-blazer-build/
My youtube channel http://www.youtube.com/user/kanesdisciple
Either get a single amp for all 4 or get the same amp for the new pair of woofers... Don't mix + match different size amps for the same sub stage.
Pioneer AVIC-N2
Morning bump!
Kinetik HC600
Powerbass 1000.1D
Powerbass 400.4
Custom Amp Rack
yeah i wouldnt have matching subs wit 2 diff make/model/power amps running them.
1998 jeep grand cherokee
future teardown and rebuild:
2-15.4 orion hcca's
sub amp undecided
2 sets of components
1-concept amp (mids/highs)
undecided h.o. alt
2-yellow tops
Hmm..... Interesting!
Kinetik HC600
Powerbass 1000.1D
Powerbass 400.4
Custom Amp Rack
It sounds like I need to look for a bigger amp for all four subs. I have been looking alot today and found this,
http://www.sonicelectronix.com/item_17599_...+BXi+2610D.html Sounds like a good amp for my subs. If anyone else has the same amp or has had one I would appreciate a review on it.
Kinetik HC600
Powerbass 1000.1D
Powerbass 400.4
Custom Amp Rack
  • Who's Online   1 Member, 0 Anonymous, 582 Guests (See full list)
