uhoh_45 Posted January 18, 2010 Report Posted January 18, 2010 im just looking for some tips pointers from anyone who's ever repaired a ski or snowboard using P-tex i've read a bunch of shit online being this is the first time ever attempting this i've read to use a torch/matches/lighter/soldering iron but donno what would be the best approach seeing as how you want the P-tex to burn blue not red/yellow/orange any help is appreciated as I R Noob at this Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
J00bles Posted January 18, 2010 Report Posted January 18, 2010 im just looking for some tips pointers from anyone who's ever repaired a ski or snowboard using P-tex i've read a bunch of shit online being this is the first time ever attempting this i've read to use a torch/matches/lighter/soldering iron but donno what would be the best approach seeing as how you want the P-tex to burn blue not red/yellow/orange any help is appreciated as I R Noob at this heat up the tip of the ptex until its getting liquid. hold the stick over the scratch and put some heat near the stick (ie: hold the lighter flame NEXT to the stick, but do not actually touch the flame to the ptex!) let the ptex drip off of the stick into the grooves and smooth it out while its still hot. thats how we do it at my work.. Quote 8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee Click to see J00bles' Youtube Channel
uhoh_45 Posted January 18, 2010 Author Report Posted January 18, 2010 smooth it out when its still hot then scrape once cold correct? Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
J00bles Posted January 18, 2010 Report Posted January 18, 2010 smooth it out when its still hot then scrape once cold correct? yep, and youll want to be sure to give it a good wax once you're done. i assumed you already scraped the old wax off? Quote 8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee Click to see J00bles' Youtube Channel
uhoh_45 Posted January 18, 2010 Author Report Posted January 18, 2010 havent done anything to it yet its still just chilling in the garage with snow on it still from the other day haha so scrape the old wax off use a base cleaner let that dry fill with p-te, mold it let it harden, scrape it and wax it Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
J00bles Posted January 18, 2010 Report Posted January 18, 2010 havent done anything to it yet its still just chilling in the garage with snow on it still from the other day haha so scrape the old wax off use a base cleaner let that dry fill with p-te, mold it let it harden, scrape it and wax it the only thing i'd add is to scrape it slightly after waxing (only if you do a hot wax) and then buff the wax with a green scotch bright pad. Quote 8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee Click to see J00bles' Youtube Channel
uhoh_45 Posted January 18, 2010 Author Report Posted January 18, 2010 so you wax as much as you can then scrape with plastic scraper i have some wax you use with an iron which i dont even have at the house so i'll have to get back to you on that topic Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
Boon Posted January 18, 2010 Report Posted January 18, 2010 (edited) How big is the hole? Hit it with base cleaner, wax remover, rubbing alcohol. You want that hole clean as hell or it'll just fall out. If it touches metal or core material, Ptex won't stick for shit. It only really bonds to existing base material. So if it's a coreshot or on an edge, you need to put epoxy in the hole first but at that point I would just take it to a shop and get a patch on it. Way more durable, Ptex in big gouges seems to last me like 3 days, especially when it gets friggin' cold (i.e BC on a bad day ) I'm also told warming the base with a (CLEAN) waxing iron can help bonding. Light your ptex candle (doesn't matter what you light it with imo) and make sure there's no smoke at all coming off it (will smoke for a little while when you first light it) or you'll get carbon in your ptex and it'll fall out. Once it's burning without soot/smoke just drip it into the gouge. Go crazy, no harm getting a big-ass pile of it. IMO it's easier to scrape when it's not totally hardened but that's up to you. Also if you use heaps it can help to knock it down with a bastard file first. Don't get the flame anywhere near your base. If you have a nicely wax-saturated base (which you probably will if you wax regularly) they burn like freakin' crazy... All that said... for anything less than real minor gouges, patch it. EDIT: Where do you ride, just out of interest? Edited January 18, 2010 by Boon Quote 10.x volts fo' life!
uhoh_45 Posted January 19, 2010 Author Report Posted January 19, 2010 (edited) its a little scrape but its long its right in the middle of the board nothing that needs epoxy and just looking at it now its got no wax on it (tried scraping with my thumb and nothing came off or anything) i'll take a picture of the board just give me a a min edit boon your PM box is full and i havent been out much this year but this over newyears i was up at sunshine in banff other then that the hill behind my place with a jump to get better doing that shit Edited January 19, 2010 by uhoh_45 Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
Boon Posted January 19, 2010 Report Posted January 19, 2010 Oops... fixed my PM box Quote 10.x volts fo' life!
