there not that deep theres just a bunch of little scrapes and what not and this is the worst of it
R.I.P!
(Nov-29-2009)
92 explorer
current build
I wouldn't even bother ptexing that to be honest. Just a good wax and scrape and you'll barely see it. A base grind would probably make it disappear.
EDIT: Cut the flakes off your topsheet with a real sharp knife and dab the exposed material with a touch of resin, otherwise they'll spread.
Edited by Boon
10.x volts fo' life!
i wanna ptex that one big one seein as how its like 2 feet long and as for the flake yeah i thought just use resin and clamp it down but if you say cut it off and resin over cant hurt doing either
R.I.P!
(Nov-29-2009)
92 explorer
current build
theres a couple thats across haha but there tiny
and as for base cleaner what would be the best to use thats commonly found around the house
R.I.P!
(Nov-29-2009)
92 explorer
current build
well i got one gouge nice and patched up but for some reason my clear ptex kept burning carbon/black and i got some in one the cracks and boy does it look ugly :( but it works for now im hoping the next time i go boarding it comes out and so i can redo it
R.I.P!
(Nov-29-2009)
92 explorer
current build
