Just hook it to a battery with a decent battery charger. done it a bunch of times
Team S.M.D.
Maritime Car Audio- (2) 18" SSA ZCON D1
- American Bass 500.1
- 60 ft of 3/0
-480 Ah of battery
- (2) stock alternators (70 +90)
- Kenwood Excelon x-794, 4v preouts
car audio is just a LOT more complicated than "this amp does this power" or "this sub will be this loud". its like 2 + 2 = banana. (if that confuses you then you get the point) lol
i heard something about computer amps?? i don't know or it works but then you dont have the problem of a battery that needs to be charged.
What you are hearing about are the pcu power units... well, they work okay i suppose... low low amperage, plus quite pricy in the end. I wired a 15" in a sealed box into my dorm room this year. I had a sealed marine 12V sitting in the garage unused. What you need to do is just wire the amplifier to the battery like normal, (fused), and put the battery onto a trickle/quick charger. I've had "0" problems in the past 3 months, other than the occasional complaints here and there, but it's mainly a weekend toy. Shakes everything in the room, i put it in my closet and it somehow works somewhat like a bandpass?! :)
On 6/30/2011 at 1:11 AM, 'Ray' said:
Acoustical energy is free. Electrical energy is not.
Or you can use a Plate Amp, or the SoundDigital FT120, in which you can run a 1000rms amp straight off it with no problems, and it doubles as a charger.
¿ǝɯɐƃ ǝɥʇ
the best way ive seen is using a old power supply out of a desk top computer it works awsome i got a toggle switch on mine so i can power it up with a flick of a switch just search around on google and u can find how to wire them id look but not at home now i know u have to connect to wires together to get it to send power thru the wires and power up that badboy i ran a rf 500.2 in my room for ever with one of these
Vehicles
93 blazer
99 cavi
big 3
2 re mt 12s
custom box 4cft 40htz
soild audio 1200 wired at .5 ohms
projects
93 s10 blazer
small bock
needing finshed
And make sure it's a sealed battery if you value your carpet and your lungs.
lol ive never used a sealed battery but i thought it was only hydrogen and oxygen that vented from them.
Team S.M.D.
- 60 ft of 3/0
-480 Ah of battery
Hydrogen goes boom if concentrated enough when introduced to an ignition source.
¿ǝɯɐƃ ǝɥʇ
