white4d96 Posted January 25, 2010 Report Posted January 25, 2010 (edited) Finally built my new box last weekend, 4.6 cubes @ 35Hz. Ran into issues placing the box that will be resolved next weekend (box has to come apart and be built in trunk) but when I do that I need to fix some air leaks in the seams. Does anybody have any recommendations as to how to fill these in? The biggest gap is on a corner and is probably about the thickness of a coin, if not slightly smaller. I would have just gone the MDF dust and glue route but all my dust got soaked in the garage, so it's not exactly usable. Edited February 17, 2010 by ktownsdriftking Quote Too many projects, too little time...
Rogers Posted January 25, 2010 Report Posted January 25, 2010 fiberglass resin! works like a charm... its like 12 bucks at walmart for a quart with a small tube of hardener... thats my best suggestion... i use it on all of my enclosures Quote http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it?
tlee2 Posted January 25, 2010 Report Posted January 25, 2010 (edited) if its only thick as a coin i would use silicon THEN resin over that Edited January 25, 2010 by tlee2 Quote 6 Sundown X 15s 2 Sundown NS1 V2s C Pillar 4th order Bagged Suburban on 24s http://youtube.com/tlee333
anubis Posted January 25, 2010 Report Posted January 25, 2010 maybe caulk with drywall joint tape then fill the outside with body filler http://www.drillspot.com/products/487788/d...ed_drywall_tape Quote 1998 Monte Carlo Z34 Stock HU but have replacement Stock Highs Stock Electrical BTL 18 sitting naked AP1500D
Rogers Posted January 25, 2010 Report Posted January 25, 2010 if its only thick as a coin i would use silicon silicon tends to not stick where mdf dust is present.. plus it likes to let go after awile anyways from the air movement... i would use the white caulk if your going to go that route... but resin will work better than anything... if the gap is large enough to slide a small piece of fiberglass matte in... i would do so... also... silicon smells like shit... resin smells good! Quote http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it?
white4d96 Posted January 25, 2010 Author Report Posted January 25, 2010 fiberglass resin! works like a charm... its like 12 bucks at walmart for a quart with a small tube of hardener... thats my best suggestion... i use it on all of my enclosures Think just one quart would do it? Quote Too many projects, too little time...
Rogers Posted January 25, 2010 Report Posted January 25, 2010 yeah if your just doing the joints... just dont mix it all at once... i normally dont mix more than 4 ounces at a time unless im making a mold of something... i used a single quart on the box for the 4 type r's... did all the joints and the vent with no problems... Quote http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it?
white4d96 Posted January 25, 2010 Author Report Posted January 25, 2010 Okay sweet. Thanks for the help =] Quote Too many projects, too little time...
mlstrass Posted January 25, 2010 Report Posted January 25, 2010 I'd be less concerned with air leaks and more worried about the box staying together. How long is the area that has the gap? You want the panels bonded together with wood glue and use caulk to seal the seams if you don't trust you glue joints to be air tight. Only takes a few seconds with a scrap piece of wood to make some sawdust. Quote
treossi Posted January 25, 2010 Report Posted January 25, 2010 resin the entire inside of the box Quote Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
