i have the following problem: the subs i use are designed to go as low as 25 hz, but 1 year ago i got into an other room which is way smaler then my old one, in my old room the lowest i could get was like 35 hz, in the new room, with the same system, the bass doesnt get any spls under like 60 hz.... is there somhow a way how i can make it go lower because this sucks!
Corner load.
Put your cabinents in the corners of your room or atleast one of them.
It should make a huge difference.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
Corner load.
Yep bass is omnidirectional so it will sound better in the corner
RE se xxx 18d2 (4)
Audioque 2200 (2)
DC Power 270XP blue
3 C&D fr310
Stinger wiring
CDT components
subs are both faced to the corners, cant put them any closer because then the cone would hit the wall, anyways, don't know the specs of the enclosure because its one of those standart things, anny suggestions how I could make a better enclosure when I build one myself? btw i found out that with one sub it allready gets better so the custom enclosure will be for 1 sub.
Knaw man don't fire the woofers into the walls.
Turn them around so they are firring into the room then leave about 3 to 4 inch around the back and the side thats against the wall and it might help.
It'll give a little room to resonate.
or fire the woofers into the oposite side thats against the wall.
So 2 sides 3 to 4 inches away from the wall and the 3rd side that you will see from your sitting position and the woofer firring towards what ever you have in there. (entertainment center, table).
Now if there is nothing inbetwean the 2 enclosures and the 2 woofers are firring directly at each other try reversing the polarity on only one of them.
all doesn't work, i think my room is just to small for the subs, it's around 2.5 by 3.5 meters... i guess thats way to small for low frequenties
  • Who's Online   0 Members, 0 Anonymous, 463 Guests (See full list)
