amplifier class
kristoffer
im looking for a 4-channel amp, and i was looking online and i found out most 4ch amp are AB class. And i was courius what that was so i google it and i found out that class AB amplifiers get hot and have high distortion.
obuisly there have to be some upsides running a AB amp since i could only find 4-channel amps that are class AB. So i would like your input on this, is overheating and distortion something i sould worry about when buying a class AB amp?
I wouldnt worry about over heating and distortion.
Class AB generally is better for full range and is most common in low power and 4ch amps.
Class D is more efficient but usually has higher distortion and lower frequency range and is mostly used for high powered Subwoofer amps.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
i have an ab 4 ch thats been kickin for years. it does get a little warm in the summer tho. only shut off once cuz of heat tho and it was mid summer on a camping trip without the car running
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
If you wanna know more about the Sq of an amp, look at its specs.
Pay attention to the S/N ratio (should be as high as possible, over 100 is good)
the frequency response (should be 20hz-20,000hz for full range)
And damping factor which is basically how well the amp controls the speaker.
And check out the amp's efficiency, the higher, the better, and the less heat.
Ed Lester
ShowtimeSPL Host
My old Build Log
  • Who's Online   0 Members, 0 Anonymous, 451 Guests (See full list)
