Carnag3 Posted February 1, 2010 Report Posted February 1, 2010 This is my second box and want to make sure the tuning is right before I built it. I used sketchup and the tuning calculator pinned in this forum. Do my port measurements look ok? I don't have much experience in ported box design. Any opinions and help appreciated Heres the specs: Box Height: 24 Box Width: 37.5 Box Depth: 34 Port Height: 6 Port Width: 25 Port Length: 34 Sub Displacement: .52 Gross airspace: 15.23 ft3 Port Volume: 3.32 ft3 Port Area: 150 in2 Net Airspace: 11.39 Tuning Frequency: 27.44 2000 Blazer 4dr -24" Boss 330s -Lowered 2/3 -5000k Hids w Projector Retro -Candy tails -LED interior lighting -20% tint 35% windshield -Alpine 9886 HU -RF P1462 Dash -RF P1652 Front -RF P1652 Rear -Two 18" Fi BTLs -MB Quart Onyx 4.80 -Two Audioque AQ2200Ds -Xs Powerr D5100, 2 Powersafe G31s -Knukoncepts 1/0 wire -Mechman 270 Alt w Boost Module -10.4 Net @ 28hz 140sq.inch of port My Youtube Channel!!
Marlo Stanfield Posted February 1, 2010 Report Posted February 1, 2010 That's all on point, at least according to Expo's calc... Why are u planning on tuning so low?? It's kinda pointless to do so unless u only listen to like chopped + screwed type music. It will be completely lacking in any sort of authority prolli beyond 35-37hz or so. You can tune in the 33-35hz range and still kill the lows, while also being able to pick up the other bass notes in music. 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
berniebp87 Posted February 1, 2010 Report Posted February 1, 2010 That seems to be right, but I would raise the tuning a bit. As Marlo said, if you raise it to 33-37hz you will have a much versatile box musicwise. This looks alot like my previous box except my box was little bit smaller and had some kerfing done to it. Was tuned a bit low, 32-33hz and that killed the lowes. It played Decafs music like a motherf###er and also could handle some rock music pretty good so it was an allround great box. Raise your tuning up a bit and you will get a great box! Proud member of SMD My build log 2 DDZ9518 2 DynaBel BF 8501 2 GZ Neo 8"s 154.5@38hz with 2 DD Z9518`s 145.5@40hz with 2 DD 1508`s My youtube vids
Carnag3 Posted February 1, 2010 Author Report Posted February 1, 2010 My main focus is on the lows, but I will definitely consider tuning it up at least to 30. Should the BTLs still pound the 28hz and under notes with this setup? And will it be safe to run the subsonic a little lower around 22 or will the subs unload? 2000 Blazer 4dr -24" Boss 330s -Lowered 2/3 -5000k Hids w Projector Retro -Candy tails -LED interior lighting -20% tint 35% windshield -Alpine 9886 HU -RF P1462 Dash -RF P1652 Front -RF P1652 Rear -Two 18" Fi BTLs -MB Quart Onyx 4.80 -Two Audioque AQ2200Ds -Xs Powerr D5100, 2 Powersafe G31s -Knukoncepts 1/0 wire -Mechman 270 Alt w Boost Module -10.4 Net @ 28hz 140sq.inch of port My Youtube Channel!!
Boon Posted February 1, 2010 Report Posted February 1, 2010 If you run your subsonic at 22 you will still be getting a large amount of power down around 18hz. And then, yes, you will become well acquainted with the sound of your coil smashing into your backplate. Followed by the sound of a slinkied coil getting tangled up in a very tight gap. Run your subsonic at your tuning frequency. It's not like a 100 percent cutoff, it's a slope... 10.x volts fo' life!
Carnag3 Posted February 2, 2010 Author Report Posted February 2, 2010 So I'm thinking of narrowing the depth of the box to allow for a rear facing port... making the messurements 27 High, 37.5 wide, and 28 deep..this should give me about 6 inches of room between the port wall and the hatch. The only problem I'm having is getting the tuning I want with those dimensions. I would like a 29-30hz tunning, but in order to tune that low I either have to have a long port, while the box is only 28 deep, or make the port smaller which yields the low tuning BUT is brings the port area slightly under the recommended amount. Any suggestions? Is it possible to make two shorter ports to allow the low tuning and large port area? I have no clue how to go about calculating tuning with 2 ports. 2000 Blazer 4dr -24" Boss 330s -Lowered 2/3 -5000k Hids w Projector Retro -Candy tails -LED interior lighting -20% tint 35% windshield -Alpine 9886 HU -RF P1462 Dash -RF P1652 Front -RF P1652 Rear -Two 18" Fi BTLs -MB Quart Onyx 4.80 -Two Audioque AQ2200Ds -Xs Powerr D5100, 2 Powersafe G31s -Knukoncepts 1/0 wire -Mechman 270 Alt w Boost Module -10.4 Net @ 28hz 140sq.inch of port My Youtube Channel!!
basslh Posted February 2, 2010 Report Posted February 2, 2010 http://www.stevemeadedesigns.com/board/ind...showtopic=63898 thats my build for my blazer check it out ***************************************** Head unit-Clarion Mids & Highs- Oxygen Audio 5.25's Highs Amp-ASA-600.4x Subs- 3 15in American Bass XFL's Sub Amps- American Bass VFL 500.1
xtremeacoustiks Posted February 2, 2010 Report Posted February 2, 2010 I suggest a rear facing port tuned around 33hz and thats just from the 20 years experience I got...just my $.02 www.bassproducers.com TEAMS TEAM BASSPRODUCERS, TEAM HERTZ (VA) *Ranger System* (4) 18" Kicker Comp (4) 10" Kicker Comp Dual Stinger Alts. (5) Rockford Punch 200's (2) Punch 100's *Outlander System*152.6 DB so Far* ( TXX-APX12W (2) AP-30001D'S (2) AP-2004'S ( APMB6'S (4) KHC2400'S
basslh Posted February 2, 2010 Report Posted February 2, 2010 I suggest a rear facing port tuned around 33hz and thats just from the 20 years experience I got...just my $.02 yup if you wont the lows i would do the same mine is tuned to 35 and its good for all music and its the lows very nice ***************************************** Head unit-Clarion Mids & Highs- Oxygen Audio 5.25's Highs Amp-ASA-600.4x Subs- 3 15in American Bass XFL's Sub Amps- American Bass VFL 500.1
