S-10 | 9ft^3 4in Under Rear Window | 4 Kicker Comp C12s | SPL:142.6 |
UPDATE: SHOULD be getting this done today...
all thats left:
Cut hole in floor under passenger seat, weld in flast spot to fit amp running highs under seat.
Wire up passenger side 4x10
charge capacitor
set gains
I think that's it...
vids when you get this done would be nice!! id love to see how this turns out
2010 Civic SI sedan: Crystal Black Pearl
All stock.
Nice looking little build :)
You can add more length to the port internally probably if it doesnt quite work out, might be easier than glassing and putting in aero's.
Hammerdown... 1%
Won't adding more length to the port just mess with the tuning?
it will make it lower, it will also decrease the volume, which will raise the tuning
but you need more port area first.
I like how you figured out you were wrong last time and apologized for being an asshole, then turn around and ignore everyone telling you not to use a cap.
loooking good, but seriously, get rid of the cap, it is seriously hurting your electrical, just sellit on craigslist or something and get a kinetik, or stinger battery, there pretty cheap and they would help everything 1000000 times more than a cap.... just shaying
wow now this just shows that smd isnt just any forum. We are a brother hood.
here let me put it in retard-onix for u aareehhhh duuuurrrrr ehhh got it now?
Sweet baby jesus the amount of quoting the quote above the quote in a quote is epic
I would... but my dad makes all the descisions.
| S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s |
SPL: 143.7 Sealed | 153.4 Port Wars
There comes a time in every man's life when you must beat up your dad. This is one of those times, so go kick his ass! Then sell the cap...
It's all gone!
The Celica Build
Feedback
If I buy something from you, DO NOT USE FEDEX!
