SMSALZER Posted February 2, 2010 Report Posted February 2, 2010 Hey all, this is one of only a few things that I have posted her so bare with me... Ive decided to upgrade my subs in my car (03 vw passat) and I am looking for a sealed enclosure that will support my 12" 2ohm Orion HC Sub-woofer. After playing around and trying to find a reasonable sealed box size I'm puzzled at the results. after some research I found that optimum Qtc Value for a sealed box is .707, so after throwing in all the subs specs into a box calculator I found that the box size should be 4.13Cf3 This seems HUGE. I realize that Qtc values generally range from .9-1.2 but i hear that .707 provides best curve and SPL levels in sealed box Orion's specs state 1Cubic foot. I know their specs are not accurate, and provide best power handling, but should I meet in the middle and build a box between .75 and .8 Qtc which states i need about 2.2 cubicfeet. I want nice bass, but i chose a sealed box because i dont want my car shaking like crazy as it would with a ported enclosure and I'm too lazy to fab a ported enclosure. Any ideas? orion hc 12.2 spec sheet Quote 2003 B5.5 Passat
SMSALZER Posted February 2, 2010 Author Report Posted February 2, 2010 In simple terms I need to know what size sealed box would sound decent for an orien hc 12.2. Quote 2003 B5.5 Passat
kirill007 Posted February 2, 2010 Report Posted February 2, 2010 Most twelves need around 1-1.5 cu ft in a sealed enclosure. So 1.2-1.3cu ft would be optimal i think. Quote Thinking is the root of all problems... You ALWAYS get what you pay for.
