hey, can someone check my numbers and my awesome picture to make sure i have this right?
2 15" nightshades -- subs up, port up --
box height - 24
depth - 16
Length - 43
Port height - 14.5
width - 6.5
length - 24
net air space 6.15ft3. port area 94.25 in2. @32.43
red is port, blue is measuring
Edited by Hostility
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
3 Sundown Audio SA-12's
Alpine H/U
RF Power Comp set 6.5"
RF 3 sixty line driver
5.25 cubes @ 31hz
Or should i do subs forward port up? im just worried of having the subs hit the seats
Edited by Hostility
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
anyone? is that enough port? and is that diagram right?
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
sounds about right man, i would do subs up port up.
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
divide you Cu.ft by your port area...You want it between 12-16 sq in per cu ft. The closer to 16 you are the more spl you will have.
1993 Mazda Mx-3
Subs: 2 18" DC Audio Lvl 4 D.7
Highs amp: Sundown SAX-100.4
Sub amp: Sundown SAZ-3000D
Electrical:Kinetik 1200 under hood, 2-Kinetik 2400 rear
All 1/0 KnuKonceptz Wire Power/Ground, Big 3, 8Ga Speaker Wire, KnuKonceptz Karma RCA's
Dampening: 120sqft 80Mil Thick Sound Destroyer Mat
Goal: 150 DB 149.9 Street Bass
yea i know between 12-16, but thats a very big difference in between, my last box was 80 sq inches of port and i felt i was chocking them, im not going for numbers at all. just ground pounder style with the loowwws, so is that port area just fine then or will i not like it to much?
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
Internal volume is wrong which means the tuning wont be that either.
internal width of 33.25" * internal depth 22.5" * internal height of 14.5" = 10847.8125in^3 / 1728 = 6.28 - .42 sub displacement = 5.86 ft^3
sorry your dimensions are wrong internal dimensions are 34.25 wide x 22.5 high x 14.5 = 11174.0625
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
5.8 is ok . They work good in that size. I did 147 with 2 15" nightshade in that size tuned to 36hz. Subs will that great in anything from 5.8-7 cuft tuned from 34 to 38 hz. I love them in 5.8 tuned to 35hz. plays eveything. I don't what type of music you like. I try everything from Coletrain to 2Pac
1993 Mazda Mx-3
well i want the box to be 6 cubes at 32 hz, i listen to a lot of e-40, too short, low bass stuff. i just dont see how the box i have in the first post is wrong?
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
  • Who's Online   2 Members, 0 Anonymous, 1206 Guests (See full list)
