tobio19 Posted February 3, 2010 Author Report Posted February 3, 2010 that is correct . ok ill try that tomorow then, 2am here.. but on the HU part, i have a stock hu, but using an req hu substitute here it is it has alot of bass filters http://www.caraudiobuy.com/product_images/...eq51__01356.jpg Quote 2006 Mazda 3 sedan Fi 18 BTL AQ2200D 7 cubes 32hz slot ported box JL mids/highs JL G-4500 Alpine CDA-105 Big 3 in 1/0 Soundstream 55ah front Amptech 100ah rear
OBI Posted February 3, 2010 Report Posted February 3, 2010 (edited) it either wires 1 ohm or 4 ohm dual 2 cannot be wired to 2 ohm.how ever connect all + and all negatives together and plug that way. if you have by accident plugged a - and a + together the sub will not play and is shorting out! What r u talking about? I hope your not talking about wiring in seires? Cause thats what it seems like you just described, and won't "short" your sub out. It will give it a 4 ohm load. Edited February 3, 2010 by OBI Quote
tobio19 Posted February 4, 2010 Author Report Posted February 4, 2010 i still cant get it working, this is the method im using Connect a piece of speaker wire between the "+" terminal of the amplifier and the "+" terminal of the first set of speaker terminals. Connect a piece of speaker wire between the "+" terminal of the first set of speaker terminals and the "+" terminal of the second set of speaker terminals. Connect a piece of speaker wire between the "-" terminal of the amplifier and the "-" terminal of the first set of speaker terminals. Connect a piece of speaker wire between the "-" terminal of the first set of speaker terminals and the "-" terminal of the second set of speaker terminals. Quote 2006 Mazda 3 sedan Fi 18 BTL AQ2200D 7 cubes 32hz slot ported box JL mids/highs JL G-4500 Alpine CDA-105 Big 3 in 1/0 Soundstream 55ah front Amptech 100ah rear
Guest Posted February 4, 2010 Report Posted February 4, 2010 i still cant get it working, this is the method im usingConnect a piece of speaker wire between the "+" terminal of the amplifier and the "+" terminal of the first set of speaker terminals. Connect a piece of speaker wire between the "+" terminal of the first set of speaker terminals and the "+" terminal of the second set of speaker terminals. Connect a piece of speaker wire between the "-" terminal of the amplifier and the "-" terminal of the first set of speaker terminals. Connect a piece of speaker wire between the "-" terminal of the first set of speaker terminals and the "-" terminal of the second set of speaker terminals. not even gonna bother reading this. wire it like this, end of story Quote
tobio19 Posted February 4, 2010 Author Report Posted February 4, 2010 not even gonna bother reading this. wire it like this, end of story thats how i did it, but it isnt working Quote 2006 Mazda 3 sedan Fi 18 BTL AQ2200D 7 cubes 32hz slot ported box JL mids/highs JL G-4500 Alpine CDA-105 Big 3 in 1/0 Soundstream 55ah front Amptech 100ah rear
k3n12ock Posted February 4, 2010 Report Posted February 4, 2010 Is your amp powering on? Quote 05 xB - (2) EVIL 18s - (2) BC3500s - NO WALL Channel 1: http://www.youtube.com/k3n12ock Channel 2: http://www.youtube.com/MrK3n12ock2
Tooshort064 Posted February 4, 2010 Report Posted February 4, 2010 (edited) What r u talking about? I hope your not talking about wiring in seires? Cause thats what it seems like you just described, and won't "short" your sub out. It will give it a 4 ohm load. pay attention PRO... if you wire the sub in parallel and on 1 voice coil you accidentley go from - to + and + to - then your shorting the sub out! I have seen people do this in the dark with little light trying to install or in a hurry not paying attention. the sub has no output but the cone will get warm! Edited February 4, 2010 by Tooshort064 Quote 95 Civic Coupe Pioneer AVH-P7600DVD Kinetik HC-1200 In Front Kinetik HC-2000 In Rear Memphis 16-MCA3004 2 X Memphis 16-MCD1000 With Maxxsonics MLX-100 2 X DC LVL 4 XL 12's Pioneer Premier TS-C720PRS In Door's Kenwood KFC-6982ie In Rear Deck All Memphis Wire/Rca's and misc.
tobio19 Posted February 4, 2010 Author Report Posted February 4, 2010 Is your amp powering on? yes amp is powering on Quote 2006 Mazda 3 sedan Fi 18 BTL AQ2200D 7 cubes 32hz slot ported box JL mids/highs JL G-4500 Alpine CDA-105 Big 3 in 1/0 Soundstream 55ah front Amptech 100ah rear
Tooshort064 Posted February 4, 2010 Report Posted February 4, 2010 do you have a DMM ? Quote 95 Civic Coupe Pioneer AVH-P7600DVD Kinetik HC-1200 In Front Kinetik HC-2000 In Rear Memphis 16-MCA3004 2 X Memphis 16-MCD1000 With Maxxsonics MLX-100 2 X DC LVL 4 XL 12's Pioneer Premier TS-C720PRS In Door's Kenwood KFC-6982ie In Rear Deck All Memphis Wire/Rca's and misc.
tobio19 Posted February 4, 2010 Author Report Posted February 4, 2010 do you have a DMM ? yes, ok hold on im uploading pics of my wiring! Quote 2006 Mazda 3 sedan Fi 18 BTL AQ2200D 7 cubes 32hz slot ported box JL mids/highs JL G-4500 Alpine CDA-105 Big 3 in 1/0 Soundstream 55ah front Amptech 100ah rear
