Ok i have a alpine type r 12. dvc..i also had a rockford 1000.bd. if i were to wire the sub at 4ohm putting 750rms to it would it sound better(CLEAN and low) than if i wired it at 2 ohm 1000rms?
in a 2001 dodge ram single cab
Bang em if you got em
The P1000-1BD is more efficient at 4 ohms as opposed to 1 ohm. However that being said you get the MOST power at 1 ohm.
is 750 watts enough to push a Type R? If it is - the go with that!
are you aware of power compression and thermal limits? Id also like to know how you are going to wire it to 4 ohm or 2 ohm. dvc 4 ohm = 8 or 2 ohm
dvc 2 ohm = 4 or 1 ohm
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
that amp is alittle to big for that sub bud...unless u got 2 of them then yea...
the only person i wouldnt let build my box would be Ray.
Team Heavy-Flex4 SA 12's tuned to 29hz
Ampere Audio 3800.1 @ 1 ohmXS Power D3100Big 3Stock alt
  • Who's Online   0 Members, 0 Anonymous, 4051 Guests (See full list)
