Had alot of requests for pricing so here it is.
Standard (you can pick 2 or 3 spiders):
10" - $415 / MSRP - $535
12" - $425 / MSRP - $550
15" - $440 / MSRP - $570
18" - $480 / MSRP - $620
OPTIONS:
Double tinsel leads* - Add $10
Nightshade Cone** - Add $10
Nightshade Spiders (you can pick 2 or 3)*** - Add $20
Additional spiders (more than 3)**** - Add $5 each
* - If you will be running an amp at 0.5 ohm or more than 2000 watts or so I suggest this. Generally speaking you will not need it if you are not an SPL competitor putting large amounts of burp power to the driver - but it is there if you want it. If you don't need them I suggest not getting them as they can chatter a bit at low volumes since they are two separate leads - probably won't hear this at all in a box listening to music, though. They are primarily designed for SPL competitors that need the extra current capacity!
** - The 18" uses the Nightshade cone, this is standard. This option is available on 10s, 12s, and 15s. Only SPL competitors will need the Nightshade cone - and even then only for VERY high power.
*** - The Nightshade spider is totally different. If you do not know why you would want them then you don't need them.
**** - I do not suggest using more than three. But if you must have them they are available.
Edited by sundownz
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
  • Who's Online   0 Members, 0 Anonymous, 2682 Guests (See full list)
