xs power d3100 or kinetik khc3800 which is better i heard the d3100 is good for 5000watts but the khc3800 is only 3800watts but the d3100 110ah and the khc3800 is 134ah which is better for these amps? ive got a khc1400 under the hood already. i need a head to head comparison .thanks
sealed up on the termlab mic on dash 4-sa12"s 2-3500d's 153.4db now testing a american bass 1100.1 no numbers yet 300amp iraggi alt and kinetik batts.
Well since you already have a kinetik under the hood...I say 4 HC2400's would suffice depending on what size alt you have.
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
4 khc3800 or d3100 which would be better and why if you had to choose ? and these where your ONLY choices.
Edited by new2boom
not sure if i would get kinetik... i have heard rumors they are going under so there would be no way to get you warranty if its true
i heard that to but its just a rumor . no matter what ill be buying im sure there will be a better battery next year so ill be buying new again for the 2011 season.
Why are u only stuck on these 2 companies?? There are others out there that make sum great batts, like Northstar.
Pioneer AVIC-N2
4-6(+1 under the hood) of either one of those fits in youre budget better. as many as you can afford, or in other words the more the better.
Edited by justin smith
justin smith
1996 mercury grand marquis
20'' bentchi b7 lexani n3000 245/35/20
cactus 5kw at 1ohm dcr(beast)
2 18'' btl's in a 14.15^ft wall tuned to 35hz with 210'' of port
kicker zx650.4
componets in still the works
200amp motorcraft alt
xs power d3100 (beast)
kenwood ddx512 h.u.
you mean my EX? the one I dumped? just remember every time you kiss her that i used to cum in her mouth
and BTW your girl just called me....
pure pwnage
  • Who's Online   1 Member, 0 Anonymous, 2137 Guests (See full list)
