Mars Blackmon Posted June 4, 2007 Report Posted June 4, 2007 a knuKonceptz distro block? and if so how do u use the compressing fittings? Quote
roscoe1129 Posted June 4, 2007 Report Posted June 4, 2007 post a pic, it may be like some others that are out there Quote Some people need a sympathetic pat... on the head...with my hammer Scientia est Vox "In Nomine Patris et Filii et Spiritus Sancti" DONT BE AFRAID TO USE THE SEARCH BUTTON!!! SMD SUPER BUYER/SELLER
Guest Nismofreak Posted June 4, 2007 Report Posted June 4, 2007 (edited) I do...Great stuff....Get the current in so I never had any problems... Anyways you need to screw out one of the terminals and then you strip like 5/8 of the wire...Insert it and then wrap the wires around the screw and screw back into place... Edited June 4, 2007 by Nismofreak Quote
Derrick824 Posted June 4, 2007 Report Posted June 4, 2007 I've used the RF stuff with compression fittings. Loosen the fitting, insert the wire, and tighten the fitting. That's it. Quote
roscoe1129 Posted June 4, 2007 Report Posted June 4, 2007 yup just like cat 5 cable loosen the fitting slip the wire in and tighten up Quote Some people need a sympathetic pat... on the head...with my hammer Scientia est Vox "In Nomine Patris et Filii et Spiritus Sancti" DONT BE AFRAID TO USE THE SEARCH BUTTON!!! SMD SUPER BUYER/SELLER
Derrick824 Posted June 4, 2007 Report Posted June 4, 2007 Thats similiar to the RF stuff. Make sure that the wire sticks out of the back side of this piece then tighten it down. Quote
Guest Nismofreak Posted June 4, 2007 Report Posted June 4, 2007 let me get some pics of mine quickly...Give my like 10 minutes Quote
Mars Blackmon Posted June 4, 2007 Author Report Posted June 4, 2007 ok thanks guys u really helped out alot Quote
Guest Nismofreak Posted June 4, 2007 Report Posted June 4, 2007 here is my pics of being installed and how it should look... Quote
