BeachJoshua Posted February 6, 2010 Report Posted February 6, 2010 Okay, so we've all heard of bass knobs, the little knob that hooks into your amp and has the power light, a min and max, and a knob... pretty simple, but what EXACTLY does it do? | S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s | SPL: 143.7 Sealed | 153.4 Port Wars
BeachJoshua Posted February 6, 2010 Author Report Posted February 6, 2010 | S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s | SPL: 143.7 Sealed | 153.4 Port Wars
Nirvalica Posted February 6, 2010 Report Posted February 6, 2010 I think it just attenuates the gain or lowers the volume of the source input. Probably different for different amps, but I'm just guessing. My Youtube Page. Check it out The "SAV" - Sub-aural Assault Vehicle Kenwood eXcelon KDC-X993 Image Dynamics CTX 6.5" Components Q-logic 6.5" kick pods CDT 6.5" CL-E6NEO Front door Midbass Kicker ZX350.4 Knukonceptz SS Karma 4 channel 6m RCA Fi Q 18" w/ brushed aluminum dust cap 7cu ft. ported box tuned to 28hz Sundown SAZ-1000D Iraggi 240 amp Amputator Alt Big 3 in Monster 1/0awg Second Skin Damplifier Lite on roof and front doors
95_1500 Posted February 6, 2010 Report Posted February 6, 2010 Some amps have bass boost knobs <--- bad Some have remote gain knobs such as Sundown Original Build http://www.stevemeadedesigns.com/board/index.php?showtopic=24095
Neo_frog Posted February 6, 2010 Report Posted February 6, 2010 That depends if you are talking about a gain knob which adjusts the gain on the amp remotely or a bass volume knob which acts as a limiter turning down the volume of your bass (or anything else you're using it for). Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
MrSkippyJ Posted February 6, 2010 Report Posted February 6, 2010 Some amps have bass boost knobs <--- badSome have remote gain knobs such as Sundown Bass boost knobs are not bad if you use them right. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
BeachJoshua Posted February 6, 2010 Author Report Posted February 6, 2010 That depends if you are talking about a gain knob which adjusts the gain on the amp remotely or a bass volume knob which acts as a limiter turning down the volume of your bass (or anything else you're using it for). Well the one I'm asking about I think it's hooked up with like a phone line cord, and it's for an MTX JH600. | S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s | SPL: 143.7 Sealed | 153.4 Port Wars
kl0wn Posted February 6, 2010 Report Posted February 6, 2010 Yeah you have bass boost knobs (that are on the amp), and remote bass knobs. If you're talking about remote bass knobs, they just control how much power the amp will output, depending on where you have it turned. Let's say to get the right output numbers out of your amp you're gain has to be half, if you have the remote bass knob plugged in and turned all the way up, the amp will act how the gain knob (on the amp) is set. It does not over-ride the gain knob on the amp, it's just like a knob to control the output of the amp quickly. Bass boost knobs are not bad if you use them right. So you're saying boosting a certain frequencies isn't bad? Every time you turn that knob, it is trying to make the amp work twice as hard (IIRC, somebody correct me if I am wrong here). And you are only boosting a certain frequency when you turn that knob (which is 45hz most of the time). 06 Mini Cooper S Sundown, SoundQubed Cadence, XS Power 151s Sealed 155s Outlaw Windshield @ 37hz
95_1500 Posted February 6, 2010 Report Posted February 6, 2010 nvm Original Build http://www.stevemeadedesigns.com/board/index.php?showtopic=24095
BeachJoshua Posted February 6, 2010 Author Report Posted February 6, 2010 Yeah you have bass boost knobs (that are on the amp), and remote bass knobs. If you're talking about remote bass knobs, they just control how much power the amp will output, depending on where you have it turned.Let's say to get the right output numbers out of your amp you're gain has to be half, if you have the remote bass knob plugged in and turned all the way up, the amp will act how the gain knob (on the amp) is set. It does not over-ride the gain knob on the amp, it's just like a knob to control the output of the amp quickly. So you can go equal to or less than the gain is set. | S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s | SPL: 143.7 Sealed | 153.4 Port Wars
