I'm pretty sure the bass knobs are the same, Crump has the one I have for the same amp.
The newer P series knobs are the same as the newer T series.
yah bro i would jump on your coils check each individual coil and then check your final out put, just know you need to be quite when ohm checking your coil haahah, try it hook up your leads read the meter and then talk watch the readings chage, hahah
-DirtyGirlProperties
Pull the sub and inspect it. I have a mayhem on only 2500 watts and the spider came loose from the cone. It still played but wasn't as loud and sounded weak. If all other connections are fine this is where I would start to diagnose the problem.
2010 Silverado
18" DC XL 18
DC 2k
XS Power Batts
Another possibility that Crump brought to me is the front battery fuse could of blown, that would explain the lack of power and how it gets quieter as it plays.
I hope that it is the problem, definitely the best case scenario. Worst case scenario would be getting my sub reconed. But you have to do what you have to do. :/
Thanks for all the help everyone.
4 18's, low power and lots of gay fur.
Team gg
Team DOA
My Videos :)
Okay, problem solved.
Fuse blown.
chyeah
EDIT: What size fuse should I use in order to be safe, but not so low that itll blow?
Edited by Slapuhho
Team gg
Team DOA
My Videos :)
Fuse blown.
chyeah
Get a 300A that way u know it wont/ shouldnt blow.
06 Impala SS
Kenwood Excelon DDX593
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
Mechman 320a Alt. w/ Big 3
Lots of Second Skin Damplifier
Under Construction for 2017
what amp do you have?
2002 ford explorer
200 amp rewound alt
single 18" Fi btl fully loaded
2 1750's
2 c&d tech 88amp/hr batts
2 ought wiring
cdt component set up front, cdt coaxials in back
Kenwood eXcelon KDC-X693
Well wouldnt that not protect my car if the it does pull too much?
Rockford T-1500-1bd
Team gg
Team DOA
My Videos :)
glad ur happier that its just the fuse, how is the whole tire thing? Heres my bullshit im dealing with (not trying to thread jack, but just off topic for u)
http://www.stevemeadedesigns.com/board/ind...mp;#entry956095
Edited by OrenB217
Black 1998 Nissan Maxima
1st Setup: 145.8 DB Outlaw @37 HZ On Music Out Of Trunk
2nd Setup: 147.8 DB @42 HZ On Music Out The Trunk
Current Trunk Build:
153.8 DB Outlaw @ 49 HZ Out the trunk (150.8 DB Sealed)
Team gg.
That sucks man.
Guys, I need more opinions.
I was told that if I get too high of a fuse, that it would damage my car and If I get a smaller one it will just blow again.
Geez. I need to know by tomorrow so we can pick it up.
Team gg
Team DOA
My Videos :)
That sucks man.
i have a 200 for 2000 watts, just dont go below what your amp supplies and dont go too high, 300 is too high from an earlier post, 200-250 is prolly perfect, doesnt matt know? Watts of amp/volts your car puts out= fuse u need
http://www.stevemeadedesigns.com/board/ind...?showtopic=1005
Edited by OrenB217
Team gg.
  • Who's Online   0 Members, 0 Anonymous, 1705 Guests (See full list)
