center channel in 07 avalanche
y do u wanta center channel IMO they're pointless
RIP The 03 prix!
New Ride
2003 Chevy Tahoe Z71
4 DC LVL 4 18s (2 currently installed)
2 DC PAI.2000 (1 currently installed)
1 DC PAI-120.4
do you mind voicing your opinion, i mean sure i can take your word for it but i'd like to know why they are pointless
R.I.P!
(Nov-29-2009)
92 explorer
current build
Not in a Escalade. In the 90th i build a center in a BMW 5er. I put out the grill from the middleventilation from the dash, build a plate from thiner wood
where i put a 4 comp in, fiered by a Rainbow monocenteramp 25 RMS range 250-5000 Hz. I slipped the RCA direct on the headunitouts in. If u have any place in ur escalade, fiberglass something for the dash. U can use a coax as well, size up till 6.5 comp or coax. Need for a centerchannel is only in an SQ build. U didnt need much power, find a little monoamp what u can throw under the dash (Phonocar have an 80 RMS for years). If the center plays alone sounds quietly, nothing big, only to fill the soundhole in middle.
"in the abundance of water, the fool is thirsty" Bob Marley
how are center channels worthless?
Think was n idea for soundholes in middle, from the times where fiberglassing was a technik for professionals. Wasnt that easy to get the speakers in good
positions without fiberglassing.
i saw a build by Steve Cooke that is somewhat similar to my avalanche and he put a center channel in the dash. Looked pretty cool. Then i looked into it and the new escalades have a factory center channel with 5.1 surround built in. Just sounded cool you know there was a time in home stereo where you just had two huge cerwin vega's on each side but now.... Just wondering about peoples experiences if it would be worth it.
  • Who's Online   0 Members, 0 Anonymous, 422 Guests (See full list)
