XS Power
AH means nothing in car audio. AH is low amperage pulls for long periods of time.
The D1200 will give you 1500watts of power as a starting battery for daily use and 3000 watts of power as a secondary battery for daily use. If you are going to compete or be doing demos, then you will want a bigger battery to help make up for the lack of alternator power.
thnx for reply, i wont be competing at all but i will starting my car in below freezing conditions (damn upstate NY). would the D1200 still be ok to replace my Autocraft Titanium in winter?
Peep my tunes...
'99 Audi A4 Q 1.8t
Knu 1/0 Big 3
Kenwood Excelon KDC-X891 HU
US Amps Merlin MD2D 2ohm @ 1000w RMS
1x RE SX10D4 in custom ported 1" MDF box 1.25cf @ 34hz
4x Audiobahn 90w RMS 4" 2-ways
2x Kenwood Excelon 110w RMS 6x9 3-ways
2x Stock Bose high door tweets
Trying to decide on what rear battery to go with for my 06 honda civic
I have a optima group 34 yellowtop up front, planning on running a saz-2500d powering 2 sa-12's and a sax-100.4, stock alt and big three with 1/0 and 1/0 to the trunk. roughly around 3140rms.
i'd eventually like to swap out my optima for xs power also.
what rear battery should i go with? and what size will fit up front thats similar to a group 34 in size?
system is mainly for daily use
How would this compare to the Stinger SPP2250?
PHCA: 2,250 amps at 80 F (5 seconds)
PCCA: 1,420 amps at 0 F (5 seconds)
Watts: 6,000
Amp Hours: 120
Reserve capacity: 273 minutes
Short circuit current: 5000 amps
This battery looks to give all top of the line battery's a run for there money
6 Funky Pup 12's
the D3400 is group 34 battery. And for the rear do you have a budget or weight limit cause if not then throw in a D3100 in the back.
Can I get a quote for a D2400 and D3100 batteries? Also, if the 2400 is my primary and rhe 3100 is in the back, will a stock 130 amp alt be enough to charge them? This is to power 2 DC 2K amps.
Watts: 6,000
Amp Hours: 120
It is larger than the D3100, so it should produce more power. Head to head they will be very close but the 3100 will hold the voltage a little higher.
Sure just give us a call. 888.497.7693 or send corona jeff a PM.
D3100 is a great battery. Here is a test of the D3100 vs other top selling group 31 batteries.
6 Funky Pup 12's
  • 2 months later...
I have a few questions. Im not familiar with all of this audio talk but I have a 2004 Chevy Impala with a stock alt and a walmart battery. I want to upgrade my battery and maybe my alt. I use my system on a daily basis and it consist of a one (1) Planet Audio 2500.1 sub amp and two (2) Kenwood 800 watt 4 channel amps. What would you recommend for me to get?
