XS Power
XS Power Battery Wattage Guide
AH means nothing in car audio. AH is low amperage pulls for long periods of time.
The D1200 will give you 1500watts of power as a starting battery for daily use and 3000 watts of power as a secondary battery for daily use. If you are going to compete or be doing demos, then you will want a bigger battery to help make up for the lack of alternator power.
thnx for reply, i wont be competing at all but i will starting my car in below freezing conditions (damn upstate NY). would the D1200 still be ok to replace my Autocraft Titanium in winter?
Peep my tunes...
'99 Audi A4 Q 1.8t
Knu 1/0 Big 3
Kenwood Excelon KDC-X891 HU
US Amps Merlin MD2D 2ohm @ 1000w RMS
1x RE SX10D4 in custom ported 1" MDF box 1.25cf @ 34hz
4x Audiobahn 90w RMS 4" 2-ways
2x Kenwood Excelon 110w RMS 6x9 3-ways
2x Stock Bose high door tweets
Trying to decide on what rear battery to go with for my 06 honda civic
I have a optima group 34 yellowtop up front, planning on running a saz-2500d powering 2 sa-12's and a sax-100.4, stock alt and big three with 1/0 and 1/0 to the trunk. roughly around 3140rms.
i'd eventually like to swap out my optima for xs power also.
what rear battery should i go with? and what size will fit up front thats similar to a group 34 in size?
system is mainly for daily use
How would this compare to the Stinger SPP2250?
PHCA: 2,250 amps at 80 F (5 seconds)
PCCA: 1,420 amps at 0 F (5 seconds)
Watts: 6,000
Amp Hours: 120
Reserve capacity: 273 minutes
Short circuit current: 5000 amps
This battery looks to give all top of the line battery's a run for there money
6 Funky Pup 12's
the D3400 is group 34 battery. And for the rear do you have a budget or weight limit cause if not then throw in a D3100 in the back.
Watts: 6,000
Amp Hours: 120
It is larger than the D3100, so it should produce more power. Head to head they will be very close but the 3100 will hold the voltage a little higher.
  • 2 months later...
I have a few questions. Im not familiar with all of this audio talk but I have a 2004 Chevy Impala with a stock alt and a walmart battery. I want to upgrade my battery and maybe my alt. I use my system on a daily basis and it consist of a one (1) Planet Audio 2500.1 sub amp and two (2) Kenwood 800 watt 4 channel amps. What would you recommend for me to get?
  • Who's Online   1 Member, 0 Anonymous, 799 Guests (See full list)
