Audioque 2200d off stock battery
I'm getting a Audioque 2200d and was wondering first off If 0/1 gauge will fit in the amp, and second will one run of 0/1 from the front be sufficient as long as I have the big 3?
Thanks
Thanks
yes 0 gauge fits and no to run it without ruining your electrical i suggest extra batts/h.o. alternator, it is very powerful
trailblazer
18" xl
aq2200
147.8db at 4 ohms
Only if your stock batt does 3000+cca and your alt does 200amps. Df gonan need a 2nd battery or one HUGe one and dont hurt to upgrade the alt. Always good to do the alt first!
1997 2 Door Blazer
Bagged & Body Dropped
SBC/TH350
Thanks man....that was my first amp and i realize that thing is a pile of garbage......btw Dro whats your electrical consist of?
well as of right now it is stock, but my amp is running at 4 ohms til i get a couple batts, i cant afford a new alt so i plan on replacing the stock battery with a kinetik and puttin a 1800 or so in the back, should work for a while. and if i run into problems down the road ill have the battery power to keep a h.o. happy
trailblazer
18" xl
aq2200
147.8db at 4 ohms
So I bought a run of knu klmx 0/1 to run to the back and I know that I need to get a battery but i have a few questions. I currently have a huge everstart battery upfront like 70-80lbs if i were to guess. Its just the normal deep cycle battery. I know its wallmart brand but for only $80 or so I could have another one. it is a group 65 with 665 CCA. Would this battery be sufficient to powering the amp untill i can upgrade to 2 higher end batteries?
  • Who's Online   1 Member, 0 Anonymous, 705 Guests (See full list)
