Project 601 `Der Trabi´ (´73 Trabant 601Kombi)
Category BB6 = 6 woofer (till six 10″ or four 12″ or double 15″ or single 18″)
that is so unfair to the single 18
R.I.P!
(Nov-29-2009)
92 explorer
current build
Nah, much better then it was before;
SINGLE WOOFER category
A single 10" versus a single 18"....
...THAT'S UNFAIR! ;)
______Some people and performances are beyond words______
Chairman of the foundation "Propper-Droppers Holland" 2012
Founder of the European delegation of `Propper-Droppers' 2011
Dutch Champion EMMA SQ MultiMedia advanced 2010
European Champion EMMA SQ experienced 5 channel 2007
Dutch Champion EMMA SQ experienced 5 channel 2007
BeNeLux vice Champion dB-drag street-A 2007
Dutch vice Champion dB-drag ministreet-sedan 2004
_________________________________________
Propper Droppers is about deep, ground wobbling, elephant-and-whale stimulating Street Bass.
The deep stuff. We test at different frequencies from deep, to low to snake’s belly. (Like 20Hz anyone?)
but from what i see here
its 6 10s vs 1 18- 4 12s vs 1 18- and 2 15s vs 1 15
6 10s = 471 ^2 cone area
4 12s = 452 ^2 of cone area
2 15s = 353 ^2 of cone area
1 18 = 254^2 of cone area
now to me that seems unfair
or theres something im missing and BB6 is somehow single woofer class
R.I.P!
(Nov-29-2009)
92 explorer
current build
Nope, you'r not missing anything because you are absolutely right. :good:
  • 1 month later...
Nominated myself for this months SOTM (and iĺl keep doing that till i win, hahahahaha)
New pics from deBunkerAudio (on tour)with PropperDroppers SPL competition at AutoMaxx Summer-Edition 2011:
Oh, forgot the latest update:
Modified the rear axle and suspension because the extra added weight of the audio.
Some cracks appeared in the metalof the rear wishbones.
We had to weld them back up, and made it it much stronger.
Furthermore we had to mount some rubber bumpstops between the rear springs.
Result: Not that much camber anymore, but more stability and quality.
:good:
  • 3 weeks later...
Holy jesus this is gorgeous. I cat believe I didnt see this sooner and for SOTM. You should DEFINITELY have gotten all the votes my friend. This is beautiful. The door panels are probably my favorite. I may do mine fairly similar...how did you attach them to the door itself? Ima need to do door poppers too.
This whole thing is just...perfect.
BTW, you're getting my recommendation for next months SOTM. :drink40:
Thank you my friend! :drinks:
About the mounting of the doorpanels:
I bolted them on my doors.
(two layers of mdf with the bold fixed between them)
Just put some nuts on the inside of the doors (use the speaker holes to get there) and you are done!
:good:
Fixed suspension!
dB Don, hotwheels, Lammers, meade916, David, mikeg321, Benji0687 and MarioB
Thank you for voting this install at SOTM August 2011 :drinks:
  • Who's Online   0 Members, 0 Anonymous, 1409 Guests (See full list)
