AudioQue 12" - with 4" aeroport
BassBoy69
so i am using a 4" aero port on my box, with a audioque 12" hdc3
everyone says i need a 6" port
any help on what i should do.
144+ DB'S OUT OF A CONVERTIBLE
12" Funky Pup Subwoofer (The worlds most powerful subwoofer)
6" Aero Ported Box
Hifonics - Bxi2010-D
Pioneer Deck
RD Audio - Front Speaker
Rockford Fosgate - Rear Speakers
KnuKonceptz - 0 Gauge Wire
KnuKonceptz SS Karma - 10 Gauge Sub Wire
KnuKonceptz - Krystal Kable Rca
Big 3 - Upgrade - 0 Gauge
Kinetik - Hc1800 Battery
use a 6"
heres the idea:
hdc love port area and really need it to excel... im guessing ur box is ~2cuft w/ 1 4" aero
thats 6.25sqin of port per cuft
change to a 6" aero
ull have 14sqin per cuft, which is much more in line with the hdc
use a 6"
heres the idea:
change to a 6" aero
Well my box specs are
15" tall
22" wide - left to right
13 1/2 wide
is this even large enough ? Can I just cut the 4" hole open more and put a 6" in there Or should i try and make the box a little bigger, because the sub its self is eating up space. and thanks for the help
o and I only have maybe a foot between the end of the port and to inside of my trunk side panel
6" Aero Ported Box
Pioneer Deck
ok so i found a site that sell the 6" ports and I can get it over knighted for 8.00 shipped.
anyone have any other thoughts? before I order.
6" Aero Ported Box
Pioneer Deck
If you swap to a larger port, then it will have to be MUCH longer to maintain the same tuning frequency. Have you calculated your port length yet using the 6 inch port?
How much power are you running on that thing, by the way?
That box is on the small side for sure. Can u make it bigger in any direction. I came up with 1.92 cuft before sub displacement on that box.
TDH FTW !!!
Are you going to competitions, or just a daily beater?
Aero ports do not require as much port area as a slot port to work properly. . . and enclosure volume does not determine require port area. . .it is just an estimate for those that can not figure out how much they really need :)
A 6" aero in ~1.8 cuft tuned to ~35 Hz will need to be 18" longer than the 4" port, so keep that in mind.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
Just ordered a 6" port with a 17" long tube.
I do have a meca comp coming up, like 8 days. - so I want to try and win, and just do well. I beat daily alot to.
I dont know anything about tuning my set up - or cutting or adding length,.. I just slapped a spare 4" port on my box to get by. I could measure it if needed.
Im using a 1998 eclipse Iv heard that you have to tune kind of high in these cars.
any help will truly be appreciated..
6" Aero Ported Box
Pioneer Deck
I could only go wider - left to right a little, I dont know how much is needed to be effective. - do you ?
The only thing is my port will be inches away from my inside trunk panel,.
I dont know if there is any other options really.
6" Aero Ported Box
Pioneer Deck
Im doing 2k,
I dont know what its tuned at right now, If i measure it can anyone tell me,.
plus I dont even know what is a proper frequency anyways.
6" Aero Ported Box
Pioneer Deck
  • Who's Online   0 Members, 0 Anonymous, 1346 Guests (See full list)
