I am trying to finish the big three upgrade on my 2002 Ford explorer (4.0 sohc0 and i seem to find out how to ground the alternator? i have a spot picked out on the chassis but do not know where to hook the wire up onto the alternator..
Thanks
2002 FORD EXPLORER PACKED WITH SOME CHEAP SUBWOOFERS!
It's grounded through the engine block.
You can just attach the wire to the bolt that screws thru the alt. into the engine block with a ring terminal. That's what I'm going to do to mine when I do my big 3 in spring.
2002 Pontiac Bonneville SSEi
Pioneer DEH-P6000UB
Alpine SPX-17REF 6.5" components (active)
Sundown SAX-50.4
Sundown z15 (3 cubes @ 35 hz)
Sundown SAX-1200D
2006 Buick Rainier CXL AWD V8
Stock Bose system
12" Alpine Type E in aeroported box
Profile AP1000M
OH well that is how i have it grounded right now... I can still hear my engine through the tweeters.. i dont know what to do...
that could be a rca issue, a deck rca issue (pioneer pico fuse) if you have a pio deck. could be a ground problem where your speaker amp is.
2005 pontiac g6
alpine 9887
mach 5 mli-65 mids w/ seas neo tweets
mb quart dsc 4125/dsc 280
2 12" mach 5 audio spls
sound digital 8k
c&d batts/red top
2 runs pos/neg in 1/0
dc power 270a sp alt
knu wiring/rcas
do you only hear it in tweets? disco them see if u hear it elsewhere if not run a ground from H/U to the firewall. If you do then look for a cut in the power wire feeding the amp it could be getting ingress
On 4/20/2010 at 10:06 PM, 'cc_audio' said:
Guys are just like girls, once you've had 18 inches you don't go back.
2004 GMC Yukon XL
Pioneer AVH-X4700BS
13 band EQ
Sub Amp- (2) PPI 5000BD.1
(2) Re SXX 15's 8 cu. ft. box tuned to 32 Hz
(4) 6.5 Bose Mids
(2) 1" Bose Tweets
(2) 1.5" Bose Tweets
(1) JY 80 AH w/ new JY busses
(1) Duracell 750 up front
Apex Alternators 270
A.C. Delco 160 alternato
ground your rca's
but alt to batterie (+) then (-) to chassie then (-) to engine block that shouldn't be your reason for the engine noise tho, if its a pioneer deck then more then im 99% sure its the rcas
BUILDLOG
http://www.stevemeadedesigns.com/board/ind...showtopic=61862
"98crewcab"Never a POS....just always "a work in progress" lol that's how we roll bitches!!!
Your a lowlife kid. I bet your mother wants to kill herself for not swallowing your ass.
It is just from the tweets, there is no cuts in the power wire either! wtf! what do you mean ground my rcas?
ground your rcas you can put a wire around them and ground them or buy a ground loop isolator for like 12 bucks
RIP The 03 prix!
New Ride
2003 Chevy Tahoe Z71
4 DC LVL 4 18s (2 currently installed)
2 DC PAI.2000 (1 currently installed)
1 DC PAI-120.4
Do like navi said. Ground the rcas coming off the back of your headunit and it will fix your engine whine. I had the same thing as you with the whine only coming from the tweeters. Cheap fix cured all of my problems.
1999 Chevy Tahoe
Level 4 15"
AP 3000d
Rockford and Phoenix Gold Componets
T400.2
Mechman 250 amp Rhino
2 Kinetik 2400
GET LOUD : STAY LOUD : SLAP RESPONSIBLY
  • Who's Online   1 Member, 0 Anonymous, 1696 Guests (See full list)
